VPN out + OpenVPN in
cotarelo
Re: VPN out + OpenVPN in
Post by cotarelo »
Also, when I disconnect from the VPN (not the OpenVPN but the one I use to anonimyse traffic) the OpenVPN starts to work normally.
When I disconnect from VPN:
sudo ss -tunlp | grep vpn
udp    UNCONN   0        0                 0.0.0.0:1194           0.0.0.0:*      users:(("openvpn",pid=24436,fd=6))
dietpi@DietPi:~$ ip -4 addr; ip -4 ro list table all; ip -4 ru
    inet 192.168.31.254/24 brd 192.168.31.255 scope global eth0
7: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 100
    inet 10.8.0.1 peer 10.8.0.2/32 scope global tun0
default via 192.168.31.1 dev eth0 table 100
default via 192.168.31.1 dev eth0 onlink
10.8.0.0/24 via 10.8.0.2 dev tun0
10.8.0.2 dev tun0 proto kernel scope link src 10.8.0.1
192.168.31.0/24 dev eth0 proto kernel scope link src 192.168.31.254
local 10.8.0.1 dev tun0 table local proto kernel scope host src 10.8.0.1
broadcast 127.0.0.0 dev lo table local proto kernel scope link src 127.0.0.1
broadcast 192.168.31.0 dev eth0 table local proto kernel scope link src 192.168.31.254
local 192.168.31.254 dev eth0 table local proto kernel scope host src 192.168.31.254
broadcast 192.168.31.255 dev eth0 table local proto kernel scope link src 192.168.31.254
0:	from all lookup local
16010:	from all sport 1194 lookup 100
32766:	from all lookup main
32767:	from all lookup default
Only the tun0 interface remains
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.31.254  netmask 255.255.255.0  broadcast 192.168.31.255
        inet6 fe80::2247:47ff:feed:9fea  prefixlen 64  scopeid 0x20<link>
        ether 20:47:47:ed:9f:ea  txqueuelen 1000  (Ethernet)
        RX packets 9548329  bytes 10711485755 (9.9 GiB)
        RX errors 0  dropped 2678  overruns 0  frame 0
        TX packets 5275915  bytes 1416320847 (1.3 GiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 20  memory 0xf7200000-f7220000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 71641  bytes 18705391 (17.8 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 71641  bytes 18705391 (17.8 MiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 10.8.0.1  netmask 255.255.255.255  destination 10.8.0.2
        inet6 fe80::c85a:4eee:abc5:765  prefixlen 64  scopeid 0x20<link>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 100  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 4  bytes 304 (304.0 B)
trendy
Post by trendy »
Do a ip route flush cache and try again.
cotarelo
Post by cotarelo »
trendy wrote: Sat Mar 27, 2021 6:52 pm Do a ip route flush cache and try again.
Thank you @trendy. The flush command does not seem to work
I guess I could ssh remotely, stop the vpn out and then use VPN in whenever I need to use it, not sure if leaving SSH connection open from outside is very secure...
trendy
Post by trendy »
Hang on, I'll try it myself. I am doing all these manipulations on the router, but I don't see why it cannot work on dietpi too.
cotarelo
Post by cotarelo »
Thank you again. I posted also this issue under reddit to check if this is related with the company that provides the vpn outgoing client : https://www.reddit.com/r/Windscribe/com ... urce=share and I did receive a reply saying it is not possible to do 🤷‍♂️
I also seen that with Dietpi the NordVPN option is available. Did any of you tied Nord outgoing and OpenVPN incoming?
trendy
Post by trendy »
Seems to be working fine for me.
dietpi@kakadu:[~]$ ip ru sh
16000:  from all sport 1190 lookup 100
dietpi@kakadu:[~]$ ip ro li tab 100
default via 172.30.30.1 dev eth0
dietpi@kakadu:[~]$ ip ro li tab main
0.0.0.0/1 via 10.17.0.1 dev proton0
10.8.0.0/24 dev tun0 proto kernel scope link src 10.8.0.1
10.17.0.0/16 dev proton0 proto kernel scope link src 10.17.0.13
107.152.101.211 via 172.30.30.1 dev eth0
128.0.0.0/1 via 10.17.0.1 dev proton0
172.30.30.0/24 dev eth0 proto kernel scope link src 172.30.30.2
dietpi@kakadu:[~]$ sudo ss -anp | grep vpn
u_str ESTAB     0      0                                            * 9676028                                             * 0                                    users:(("openvpn",pid=10277,fd=2),("openvpn",pid=10277,fd=1))
u_dgr ESTAB     0      0                                            * 9676064                                             * 0                                    users:(("openvpn",pid=10277,fd=3))
udp   UNCONN    0      0                                      0.0.0.0:38907                                         0.0.0.0:*                                    users:(("openvpn",pid=9785,fd=3))
udp   UNCONN    0      0                                      0.0.0.0:1190                                          0.0.0.0:*                                    users:(("openvpn",pid=10277,fd=6))
dietpi@kakadu:[~]$ sudo iptables-save -c
# Generated by xtables-save v1.8.2 on Tue Mar 30 17:30:42 2021
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
COMMIT
# Completed on Tue Mar 30 17:30:42 2021
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
[407:32474] -A POSTROUTING -s 10.8.0.0/24 -o eth0 -m comment --comment openvpn-nat-rule -j MASQUERADE
[121:10093] -A POSTROUTING -s 10.8.0.0/24 -o proton0 -m comment --comment proton-nat-rule -j MASQUERADE
COMMIT
dietpi@kakadu:[~]$ sudo tcpdump -i any -evn icmp
tcpdump: listening on any, link-type LINUX_SLL (Linux cooked), capture size 262144 bytes
17:30:59.542795  In ethertype IPv4 (0x0800), length 100: (tos 0x0, ttl 50, id 41395, offset 0, flags [DF], proto ICMP (1), length 84)
    10.8.0.2 > 147.52.80.1: ICMP echo request, id 1221, seq 1, length 64
17:30:59.543084 Out ethertype IPv4 (0x0800), length 100: (tos 0x0, ttl 49, id 41395, offset 0, flags [DF], proto ICMP (1), length 84)
    10.17.0.13 > 147.52.80.1: ICMP echo request, id 1221, seq 1, length 64
17:30:59.763061  In ethertype IPv4 (0x0800), length 100: (tos 0x28, ttl 49, id 40881, offset 0, flags [none], proto ICMP (1), length 84)
    147.52.80.1 > 10.17.0.13: ICMP echo reply, id 1221, seq 1, length 64
17:30:59.763241 Out ethertype IPv4 (0x0800), length 100: (tos 0x28, ttl 48, id 40881, offset 0, flags [none], proto ICMP (1), length 84)
    147.52.80.1 > 10.8.0.2: ICMP echo reply, id 1221, seq 1, length 64
I used 1190 in my case, but this doesn't matter.
Openvpn server was created with pivpn package of dietpi. OpenVPN client is running with protonvpn profile.
One thing I had to do manually was to add the proton masquerade rule in iptables.
As you can see in tcpdump android phone client (10.8.0.2) sends an icmp echo request to dietpi over ISP, then dietpi (10.17.0.13) forwards it to protonvpn tunnel, receives the reply, and sends it to the android phone over eth0.
