Webmin Topic is solved
Re: Webmin
For the systemd restart feature we'd need to find the exit code or signal when an internal restart is done. This can then be used to trigger a systemd restart conditionally. Otherwise we'd either prevent an intended stop or have a restart loop on failure. With a wrapper script it's actually the same, but we have more tools like checking for the process that performs the restart. I'll run some tests next week.
Re: Webmin
well adding StartLimitBurst should prevent uncontrolled restart loops and stop the service after a specified attempts, isn't it?
Re: Webmin
Jep exactly. It's still not perfect as in cases when users change settings often, frequent restarts may be expected while hitting the limit. But until we find a better solution via exit code or signal, it's an option.
Burgess85
Re: Webmin
Post by Burgess85 »
Do I need to change anything?
Re: Webmin
Well you could try to adjust your webmin service file as follow. It would be a workaround until a final solution was found
[Unit]
Description=Webmin (DietPi)
StartLimitIntervalSec=500
StartLimitBurst=5
[Service]
Restart=always
RestartSec=5s
Type=forking
ExecStart=/etc/webmin/start
ExecStop=/etc/webmin/stop
[Install]
WantedBy=multi-user.target
Burgess85
Re: Webmin
Post by Burgess85 »
Did you have an update please?
Re: Webmin
as stated above, you can adjust your service file as workaround.
Burgess85
Re: Webmin
Post by Burgess85 »
Sorry where do I find it?
Re: Webmin
you can do it on a drop-in config for webmin service
nano /etc/systemd/system/webmin.service.d/dietpi-services_edit.conf
and add
[Unit]
StartLimitBurst=5
[Service]
Restart=always
RestartSec=5s
once done
systemctl daemon-reload
systemctl restart webmin.service
Re: Webmin
Alternative solution has now been implemented for DietPi v7.2: https://github.com/MichaIng/DietPi/pull/4331
Quick test of the approach would be:
sed -i '/\[Service\]/a\GuessMainPID=no' /etc/systemd/system/webmin.service
