Automatic Login LXDE
tiffe
Re: Automatic Login LXDE
Post by tiffe »
Joulinar wrote: Sat Mar 20, 2021 7:34 am Plus can you connect via SSH and provide the log file. The name is specified on the last lines of the error message
root@DietPi:~# cat /var/log/Xorg.0.log
[    22.231]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[    22.231] Build Operating System: Linux 4.19.0-12-armmp-lpae armv7l Debian
[    22.231] Current Operating System: Linux DietPi 4.14.180+ #1 SMP PREEMPT Tue Oct 13 13:28:54 UTC 2020 armv7l
[    22.232] Kernel command line: console=tty1 console=ttySAC2,115200n8 root=UUID=e139ce78-9841-40fe-8823-96a304a09859 rootwait ro fsck.repair=yes net.ifnames=0 drm_kms_helper.edid_firmware=edid/1280x1024.bin smsc95xx.macaddr=00:1e:06:61:7a:72 governor=performance hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi  s5p_mfc.mem=16M
[    22.232] Build Date: 01 December 2020  05:59:57PM
[    22.232] xorg-server 2:1.20.4-1+deb10u2 (https://www.debian.org/support)
[    22.232] Current version of pixman: 0.36.0
[    22.232] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    22.232] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    22.233] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 20 20:30:51 2021
[    22.236] (==) Using config file: "/etc/X11/xorg.conf"
[    22.237] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    22.237] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    22.240] (==) ServerLayout "DefaultLayout"
[    22.240] (**) |-->Screen "Default Screen" (0)
[    22.240] (**) |   |-->Monitor "<default monitor>"
[    22.241] (**) |   |-->Device "Mali-Fbdev"
[    22.241] (==) No monitor specified for screen "Default Screen".
	Using a default monitor configuration.
[    22.241] (**) Option "BlankTime" "0"
[    22.241] (**) Option "StandbyTime" "0"
[    22.241] (**) Option "SuspendTime" "0"
[    22.241] (**) Option "OffTime" "0"
[    22.241] (==) Automatically adding devices
[    22.241] (==) Automatically enabling devices
[    22.241] (==) Automatically adding GPU devices
[    22.241] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    22.246] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    22.246] 	Entry deleted from font path.
[    22.246] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    22.246] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    22.246] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[    22.246] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    22.246] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    22.246] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	built-ins
[    22.246] (==) ModulePath set to "/usr/lib/xorg/modules"
[    22.246] (**) Extension "DPMS" is disabled
[    22.246] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    22.246] (II) Loader magic: 0x61af98
[    22.246] (II) Module ABI versions:
[    22.246] 	X.Org ANSI C Emulation: 0.4
[    22.246] 	X.Org Video Driver: 24.0
[    22.246] 	X.Org XInput driver : 24.1
[    22.246] 	X.Org Server Extension : 10.0
[    22.248] (++) using VT number 1
[    22.251] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[    22.253] (II) xfree86: Adding drm device (/dev/dri/card0)
[    22.254] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[    22.254] (II) no primary bus or device found
[    22.254] 	falling back to /sys/devices/platform/exynos-drm/drm/card0
[    22.254] (II) LoadModule: "glx"
[    22.256] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    22.277] (II) Module glx: vendor="X.Org Foundation"
[    22.277] 	compiled for 1.20.4, module version = 1.0.0
[    22.277] 	ABI class: X.Org Server Extension, version 10.0
[    22.277] (II) LoadModule: "armsoc"
[    22.278] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[    22.280] (II) Module armsoc: vendor="X.Org Foundation"
[    22.280] 	compiled for 1.20.4, module version = 1.4.1
[    22.280] 	Module class: X.Org Video Driver
[    22.280] 	ABI class: X.Org Video Driver, version 24.0
[    22.280] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[    22.280] (WW) Falling back to old probe method for armsoc
[    22.281] (II) No BusID or DriverName specified - opening /dev/dri/card0
[    22.281] (EE) ERROR: Cannot set the DRM interface version.
[    22.281] (EE) ERROR: Cannot open a connection with the DRM - Permission denied
[    22.281] (WW) Falling back to old probe method for armsoc
[    22.281] (EE) No devices detected.
[    22.281] (EE)
Fatal server error:
[    22.281] (EE) no screens found(EE)
[    22.281] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    22.281] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    22.281] (EE)
[    22.292] (EE) Server terminated with error (1). Closing log file.
MichaIng wrote: Sat Mar 20, 2021 2:03 pm Just to assure, this was now as root user?
Yes this is using Autostart "option 2" with user "root"
This as root is strange indeed. The same error happens when you run startx from console?
What does the following show?
ls -l /dev/dri/card0
wow permission denied for user root. That's quite a secure system ;)
Sorry for the joke :P
