Problem with migration from Rpi to PC Topic is solved
Re: Problem with migration from Rpi to PC
the user data folder needs to be writable by www-data user. For the backup.sql, read permissions should be enough
przemko
Post by przemko »
I set permissions to www-data user to backup.sql file but it don't help. I set new users and now everything is OK. Thank You very much.
Regards.
