Nextcloud stuck in maintenance mode - php module cURL not installed Topic is solved
Totila
Re: Nextcloud stuck in maintenance mode - php module cURL not installed
Post by Totila »
Solved it:
sudo update-alternatives --set php /usr/bin/php7.3
apt install --reinstall php7.3-curl
Nextcloud was up and running again using php7.3 now.
Did not uninstall 8.0
Thanks for your support.
T
ok good that it is working now.
It should be removed, and the meta package that always pulls the latest PHP major version from Ondrej's repo: G_AGP php 'php8.0*'
Latest Nextcloud 21 btw is PHP8.0-compatible, but probably not all other software titles.
