XU4 CloudShell Stopped Working Topic is solved
Fourdee
Re: XU4 CloudShell Stopped Working
Post by Fourdee »
Fabian0587 wrote:You mean this?
d3edd838-bc6f-41a0-bcb5-ec3e88a430c7-0
Yep, thats the puppy, thanks.
Had a look through, nothing out of the normal, so we'll need to run a few tests on your devices until we find a fix.
Please run test 1 and paste results of service status at end:
https://github.com/Fourdee/DietPi/issue ... -267615273
Fabian0587
Post by Fabian0587 »
Output of test n1
root@DietPi:~# cat << _EOF_ > /etc/systemd/system/dietpi-cloudshell.service
> [Unit]
> Description=dietpi-cloudshell on main screen
> [Service]
> Type=forking
> StandardOutput=tty
> # These are run from dietpi-cloudshell and autostart
> ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersave off
> ExecStartPre=/usr/bin/tput civis
s> ExecStart=/bin/bash -c '/DietPi/dietpi/dietpi-cloudshell 1 &'
> ExecStop=/usr/bin/setterm -reset
> ExecStop=/bin/bash -c '/DietPi/dietpi/func/dietpi-notify 0 DietPi-Cloudshell t erminated, have a nice day!'
> [Install]
> WantedBy=multi-user.target
> _EOF_
root@DietPi:~# systemctl daemon-reload
root@DietPi:~# systemctl stop dietpi-cloudshell
root@DietPi:~# systemctl start dietpi-cloudshell
Job for dietpi-cloudshell.service failed because the control process exited with error code.
See "systemctl status dietpi-cloudshell.service" and "journalctl -xe" for detail s.
root@DietPi:~# systemctl status dietpi-cloudshell -l
● dietpi-cloudshell.service - dietpi-cloudshell on main screen
Loaded: loaded (/etc/systemd/system/dietpi-cloudshell.service; disabled; vend
Active: failed (Result: exit-code) since Fri 2016-12-16 18:45:04 CET; 3s ago
Process: 2508 ExecStartPre=/usr/bin/tput civis (code=exited, status=1/FAILURE)
Process: 2505 ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersave
Dec 16 18:45:04 DietPi systemd[1]: Starting dietpi-cloudshell on main screen...
Dec 16 18:45:04 DietPi systemd[1]: dietpi-cloudshell.service: Control process ex
Dec 16 18:45:04 DietPi systemd[1]: Failed to start dietpi-cloudshell on main scr
Dec 16 18:45:04 DietPi systemd[1]: dietpi-cloudshell.service: Unit entered faile
Dec 16 18:45:04 DietPi systemd[1]: dietpi-cloudshell.service: Failed with result
lines 1-11/11 (END)...skipping...
Loaded: loaded (/etc/systemd/system/dietpi-cloudshell.service; disabled; vendor preset: enabled)
Process: 2505 ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersave off (code=exited, status=0/SUCCESS)
Dec 16 18:45:04 DietPi systemd[1]: dietpi-cloudshell.service: Control process exited, code=exited status=1
Dec 16 18:45:04 DietPi systemd[1]: Failed to start dietpi-cloudshell on main screen.
Dec 16 18:45:04 DietPi systemd[1]: dietpi-cloudshell.service: Unit entered failed state.
Dec 16 18:45:04 DietPi systemd[1]: dietpi-cloudshell.service: Failed with result 'exit-code'.
Fourdee
Post by Fourdee »
Fabian0587 wrote:Output of test n1
Thanks,
Please try Test 2:
https://github.com/Fourdee/DietPi/issue ... -267615706
And Test 3:
https://github.com/Fourdee/DietPi/issue ... -267615916
Fabian0587
Output of test n2
> [Unit]
D> Description=dietpi-cloudshell on main screen
> [Service]
> Type=forking
E> StandardOutput=tty
> ExecStop=/bin/bash -c '/DietPi/dietpi/func/dietpi-notify 0 DietPi-Cloudshell terminated, have a nice day!'
> [Install]
> _EOF_
Active: active (running) since Fri 2016-12-16 19:26:52 CET; 1s ago
Process: 2611 ExecStart=/bin/bash -c /DietPi/dietpi/dietpi-cloudshell 1 & (code=exited, status=0/SUCCESS)
Main PID: 2612 (dietpi-cloudshe)
CGroup: /system.slice/dietpi-cloudshell.service
├─2612 /bin/bash /DietPi/dietpi/dietpi-cloudshell 1
└─2674 sleep 0.2
Dec 16 19:26:52 DietPi systemd[1]: Starting dietpi-cloudshell on main screen...
Dec 16 19:26:52 DietPi systemd[1]: Started dietpi-cloudshell on main screen.
Output of test n.3
> [Unit]
> [Service]
> Type=forking
> StandardOutput=tty
sy> ExecStart=/bin/bash -c '/DietPi/dietpi/dietpi-cloudshell 1 &> /dev/tty1 &'
> [Install]
> _EOF_
Active: active (running) since Fri 2016-12-16 19:27:35 CET; 3s ago
Process: 2787 ExecStart=/bin/bash -c /DietPi/dietpi/dietpi-cloudshell 1 &> /dev/tty1 & (code=exited, status=0/SUCCESS
Main PID: 2788 (dietpi-cloudshe)
├─2788 /bin/bash /DietPi/dietpi/dietpi-cloudshell 1
└─2873 sleep 0.2
Dec 16 19:27:35 DietPi systemd[1]: Starting dietpi-cloudshell on main screen...
Dec 16 19:27:35 DietPi systemd[1]: Started dietpi-cloudshell on main screen.
lines 1-11/11 (END)
AAAAAAAAAAAAAAND it worked again!
Thanks Fourdee!
Just a note. Ram has a negative value -1516/1990
Fourdee
Post by Fourdee »
Fabian0587 wrote: AAAAAAAAAAAAAAND it worked again!
Thanks Fourdee!
Excellent, this is just a workaround for now, i'll create a complete fix and let you know.
Interesting, i'll take a look.
Saturn7
Post by Saturn7 »
This worked for me too. Thanks!
Fourdee
Post by Fourdee »
Hi all,
Need some assistance testing a solution.
Please can you run test 4: https://github.com/Fourdee/DietPi/issue ... -267771135 and let me know results.
Saturn7
Post by Saturn7 »
Fourdee wrote:Hi all,
> [Unit]
> [Service]
> Type=forking
> StandardOutput=tty
> ExecStartPre=/usr/bin/tput civis &> /dev/tty1 #: https://github.com/Fourdee/DietPi/issues/649
> ExecStop=/usr/bin/tput reset &> /dev/tty1
> [Install]
> _EOF_
systemctl status dietpi-cloudshell -lroot@DietPi:~# systemctl stop dietpi-cloudshell
Job for dietpi-cloudshell.service failed. See 'systemctl status dietpi-cloudshell.service' and 'journalctl -xn' for details.
   Loaded: loaded (/etc/systemd/system/dietpi-cloudshell.service; disabled)
   Active: failed (Result: exit-code) since Sat 2016-12-17 18:30:48 GMT; 3s ago
  Process: 19620 ExecStartPre=/usr/bin/tput civis &> /dev/tty1 #: https://github.com/Fourdee/DietPi/issues/649 (code=exited, status=1/FAILURE)
  Process: 19617 ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersave off (code=exited, status=0/SUCCESS)
Dec 17 18:30:48 DietPi systemd[1]: dietpi-cloudshell.service: control process exited, code=exited status=1
Dec 17 18:30:48 DietPi systemd[1]: Failed to start dietpi-cloudshell on main screen.
Dec 17 18:30:48 DietPi systemd[1]: Unit dietpi-cloudshell.service entered failed state.
Fabian0587
If you need a second opinion :D
> [Unit]
> [Service]
> Type=forking
> StandardOutput=tty
> ExecStartPre=/usr/bin/tput civis &> /dev/tty1 #: https://github.com/Fourdee/Di etPi/issues/649
systemctl st> ExecStart=/bin/bash -c '/DietPi/dietpi/dietpi-cloudshell 1 &'
> [Install]
> _EOF_
Active: failed (Result: exit-code) since Sun 2016-12-18 13:07:32 CET; 94ms ag
Process: 3965 ExecStartPre=/usr/bin/tput civis &> /dev/tty1 #: https://github.
Process: 3962 ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersave
Dec 18 13:07:32 DietPi systemd[1]: Starting dietpi-cloudshell on main screen...
Dec 18 13:07:32 DietPi systemd[1]: dietpi-cloudshell.service: Control process ex
Dec 18 13:07:32 DietPi systemd[1]: Failed to start dietpi-cloudshell on main scr
Dec 18 13:07:32 DietPi systemd[1]: dietpi-cloudshell.service: Unit entered faile
Dec 18 13:07:32 DietPi systemd[1]: dietpi-cloudshell.service: Failed with result
Active: failed (Result: exit-code) since Sun 2016-12-18 13:07:32 CET; 94ms ago
Process: 3965 ExecStartPre=/usr/bin/tput civis &> /dev/tty1 #: https://github.com/Fourdee/DietPi/issues/649 (code=exited, status=1
Process: 3962 ExecStartPre=/usr/bin/setterm --term linux --blank 0 --powersave off (code=exited, status=0/SUCCESS)
Dec 18 13:07:32 DietPi systemd[1]: dietpi-cloudshell.service: Control process exited, code=exited status=1
Dec 18 13:07:32 DietPi systemd[1]: Failed to start dietpi-cloudshell on main screen.
Dec 18 13:07:32 DietPi systemd[1]: dietpi-cloudshell.service: Unit entered failed state.
Dec 18 13:07:32 DietPi systemd[1]: dietpi-cloudshell.service: Failed with result 'exit-code'.
Fourdee
Post by Fourdee »
Thanks guys,
Looks like we will need to move tput out of the service altogether. I'll create another test and let you guys know when its ready. Thanks again.
