Dietpi first run setup failed
menacing_jon
Re: Dietpi first run setup failed
Post by menacing_jon »
So what should I do next?
I guess the partition got extended successfully, but the filesystem did not. Just to be sure about this, could you paste:
lsblk -no SIZE,FSSIZE /dev/mmcblk0p2
findmnt -no SIZE /
It the second number of the first command and the second command verify it. Please try to resize the filesystem manually:
resize2fs /dev/mmcblk0p2
