Dietpi first run setup failed
menacing_jon
Re: Dietpi first run setup failed
Post by menacing_jon »
The same first error
and there is still no dietpi-firstrun-setup.log?
are there any other error messages before this one?
menacing_jon
no
ok I'm out of ideas
@MichaIng
can you have a look pls
menacing_jon
Is there a version 7 download link instead of version 6?
DietPi v7.0 has been released last night, and there is no image available containing v7 already. But it will do the very same thing as you are failing on quite an early state.
menacing_jon
ok
Let's see how/where the setup fails:
cat /boot/dietpi/.install_stage
df -T
G_CHECK_FREESPACE / 500
menacing_jon
This?
it still the issue with missing free space as already indicated dietpi-firstboot.log viewtopic.php?p=32179#p32179
[FAILED] DietPi-Set_swapfile | Free space check: path=/var/ | available=86 MiB | required=1144 MiB
[FAILED] DietPi-Set_swapfile | Insufficient free space for desired swap files size
however this does not fit to following 2 information
fs_partition_resize.log viewtopic.php?p=32183#p32183
lsblk -o viewtopic.php?p=32191#p32191
Maybe I have overseen something :?
