Dietpi first run setup failed
menacing_jon
Re: Dietpi first run setup failed
Post by menacing_jon »
This is what I get
hmm that looks fine and there is no
dietpi-firstrun-setup.log
inside /var/tmp/dietpi/logs?
can you share
menacing_jon
Wont let me see that log file, saying there is no such directory
ls -la /var/tmp/dietpi/logs
menacing_jon
This?
before trying to repeat the first run. can you post lsblk -o name,fstype,label,size,ro,type,mountpoint,partuuid,uuid
menacing_jon
Here
ok let's try to re-run the initial boot
systemctl enable dietpi-firstboot.service
reboot
pls have a look to error messages on screen
menacing_jon
Did that, and still brought me to the same error
can you share that error?
