Nextcloud - Internal Server Error (after apt-upgrade) Topic is solved
Re: Nextcloud - Internal Server Error (after apt-upgrade)
This has nothing to do with DietPi directly. You are running an older image version of Debian Stretch as base OS. DietPi is just some scripting on top ;)
But to verify, simply check on Nextcloud for an available update. The last days version 21 has been released.
At least on a DEMO system, running Stretch, I was able to install NextCloud 21 without issues.
fhals
Post by fhals »
Thank you for the clarification.
I will post any success here ;)
Yes, officially the MariaDB version shipped with Debian Stretch is not supported anymore by Nextcloud 21, but it's still possible to install it. The admin panel shows the somehow wrong info then :D:
MariaDB version "10.1.48-MariaDB-0+deb9u1" is used. Nextcloud 21 will no longer support this version and requires MariaDB 10.2 or higher.
When installing NC20, and switching to beta branch (as it's rolled out in waves), NC21 is offered by the web UI and run through nicely.
Means, for now we can keep allowing fresh Nextcloud installs on Stretch, but I guess with NC22 at least we need to hardcode a lower version for Stretch.
