Nextcloud 21 released and won't install on dietpi Topic is solved
Re: Nextcloud 21 released and won't install on dietpi
I guess the solution for this issue is inside the GitHub post you linked
https://github.com/nextcloud/server/iss ... -784076813
m2m
Post by m2m »
I now have nc running again. The only thing that helped me was to comment out memcache/redis in config.php.
Probably not a good solution in the long run.
/*'memcache.local' => '\\OC\\Memcache\\APCu',
'filelocking.enabled' => true,
'memcache.locking' => '\\OC\\Memcache\\Redis',
'redis' =>
array (
'host' => '/var/run/redis/redis-server.sock',
'port' => 0,
'timeout' => 0,
'password' => '',
droogi
Post by droogi »
for information. dietpi v7.0.2:
I updated nextcloud 20.0.9 via the web updater to 21.0.1, it worked well.
Also talk 11.1.2 works well.
i added manually the line 'default_phone_region' => 'DE', to /var/www/nextclooud/config/config.php
Only remaining "failure message" is
Dein Web-Server ist nicht richtig eingerichtet um
  • "/.well-known/webfinger"
  • "/.well-known/nodeinfo"
aufzulösen. Weitere Informationen findest Du in der Dokumentation.
Regards, droogi
maybe you can have a look to the NextCloud forum https://help.nextcloud.com/t/nextcloud- ... /108772/17
droogi
Post by droogi »
thanks Joulinar for the hint, but this is for apache. Nextcloud is installed with nginx.
I think it should be configured in /etc/nginx/sites-dietpi/diet-dav_redirect.conf, but i am not sure about this and the syntax.
nextcloud help points to
https://docs.nextcloud.com/server/21/ad ... nx-webroot
Regards, droogi
probably you can connect to the topic on the nextcloud forum as they are talking about nginx as well.
