If you really like you can follow this linke to share a coffee
https://dietpi.com/contribute.html
It's either the Raspberry Pi kernel or the Debian dosfsutils and/or mount packages, it does not play well with. It's obviously not auto-mounting (you mean systemd automount feature), but mounting such drive in general
Well, after configuring other applications through DietPi, and subsequently having to reboot both Pi's a few times, the issue is back. At this point, I don't even care - I am leaving it as is and will deal with the issue if the Pi's are ever rebooted.MichaIng wrote: ↑Sat Feb 20, 2021 1:32 pm Great that it works now.
It's either the Raspberry Pi kernel or the Debian dosfsutils and/or mount packages, it does not play well with. It's obviously not auto-mounting (you mean systemd automount feature), but mounting such drive in general.
Another question, did you format the drive on Windows? Probably formatting it on Linux/DietPi would have worked. I'll keep the case in mind if something similar is reported again.
dwr - SpicyLimes.io
