Use second hard disk in samba network for storage Topic is solved
nanooker
Re: Use second hard disk in samba network for storage
Post by nanooker »
I have created a backup of dietpi.
I wanted to save this backup on the HDD2.
The HDD2 is mounted as "mnt/dietpi_userdata/HDD2".
After the backup I got the error message that I can not save this on dietpi_userdata/HDD2. I also did not find the created backup.
When I go to properties of the HDD2 disk in the network, I see 292 GB. But the disk has only 150 GB.
The HDD1 has 292GB.
Somehow I can't get through this.
I think I will uninstall everything and start over.
It is correctly shown the disk space of your HDD1. Samba did not know that you have a 2nd disk attached. It will show space of the disk where the main folder is located on. If you like to see space of HDD2, you would need to mount it to /mnt/HDD2 and create a 2nd samba export that would need to be mounted as an additional drive on windows.
Regarding the backup issue. pls can you share some error message
nanooker
Post by nanooker »
I do not have any errors. Backup is running. Only where does dietpi save that?? Can't find it in my folders on the hard drives. As path I have Current backup and restore location: │
│ - /mnt/dietpi/HDD2/backups/
specified.
if you backup your data to /mnt/dietpi/HDD2/backups/ they are for sure not visible on your samba share because you are sharing a different directory /mnt/dietpi_userdata/ ;)
I guess you tried to backup to /mnt/dietpi_userdata/HDD2/backups but maybe specified incorrect folder.
nanooker
Post by nanooker »
Yes, I think that's how it will be. I will try again tomorrow
Thank you
nanooker
Post by nanooker »
I have tried this several times now to create a backup. The backup runs, and completes successfully. only after the process, no file is present. I think this has something to do with the configured disks? I send a screenshot of the Drive Manager. There are only 13 GB on my large disc.
Where did you store the backup? What is the target location?
nanooker
Post by nanooker »
with mnt/dietpi-userdata
It is reported that I cannot make a backup of user data.
With mnt/dietpi-backup as requested, the following message appears
The backup target location appears to have insufficient free space to successfully finish the backup.
backup.
│ However, this check is a rough estimation in reasonable time, thus it could be marginally │ incorrect.
│ incorrect.
Would you like to override this warning and continue with the backup?
<Ignore> <Exit>
Although I still have enough free space
well it depends how much data would need to be backup. Did you ingore the message and continue the back run?
nanooker
Post by nanooker »
No,but i will try, thank you
