insgesamt 28
drwxr-xr-x 4 root root 4096 Feb 9 10:43 .
drwxrwxr-x 8 dietpi dietpi 4096 Feb 9 13:12 ..
drwxr-xr-x 3 root root 4096 Feb 9 10:43 dietpi_userdata
drwx------ 2 root root 16384 Feb 8 15:11 lost+found
Use second hard disk in samba network for storage Topic is solved
Re: Use second hard disk in samba network for storage
ok the folder is owned by user
you could try changing whole content of your HDD to belong to user
root
. But access on SAMBA is done by user dietpi
. Therefore is fine to have permission issues
dietpi
chmod -R dietpi:dietpi /mnt/dietpi_userdata/HDD2
issue:
issue
chmod: Invalid mode: "dietpi:dietpi"
"chmod --help" provides more information.
root@yellowsnow:~# chmod -R dietpi:dietpi /mnt/dietpi_userdata/HDD2
"chmod --help" provides further information.
issue
ah sorry my fault
chown -R dietpi:dietpi /mnt/dietpi_userdata/HDD2
Wonderful works perfectly.
Hopefully I still know that next time or a possible reinstallation. I guess it can not be simpler?
Thank you very much for the help. I would never have managed alone.
well it's already quite simple
- add drive to correct place
- use correct permissions
Thanks again!
Do I need to mark the post as done where?
And where should I send the box of wine / beer?
I marked it as solved already.
If you like to support the entire project, simple follow this link https://dietpi.com/#donate
Sorry I have to ask again
I wanted to create a backup on the second hard drive.
This apparently does not work because of "mnt/userdata".
pls can you be a little bit more specific what you have tried and what was the error you faced.
