How can I setup Ombi to run as a startup service ? Topic is solved
Re: How can I setup Ombi to run as a startup service ?
There is no conflict between Omni, NextCloud and Emby. All 3 are running fine next to each other.
Not sure what SWAG is, how it is working and how it is handling certificates. But you would need to disable https on nextcloud. Otherwise you will have a port conflict.
przemko
Post by przemko »
Yes, but Ombi need reverse proxy to work in internet and reverse proxy need port 443.
Maybe You know other method to use SSL with Ombi and not conflict with my apps?
Regards.
There is no conflict. You just need to reconfigure your setup. You can use your current web server as revers proxy or you install a dedicated software for this. Either way, you need to configure and setup the scenario.
przemko
Post by przemko »
What do You mean reconfigure my config and use my web server as reverse proxy? I'm totally noob and don't know how to start. Only knowledge I have is what You tell me on forum.
Regards.
przemko
Post by przemko »
Can I use frp:reverse proxy or HAProxy from Dietpi-software?
it dosne't matter which proxy solution you choose, you will need to make port 80/443 available. Means adjusting configuration on your web server. Probably easiest for you would be to use your web server as revers proxy and not to install a software in addition. I guess you are using Lighttpd. Unfortunately not the easiest one to configure as revers proxy but you could search the web if you find an example configuration Ombi + Lighttpd.
