How can I setup Ombi to run as a startup service ? Topic is solved
Re: How can I setup Ombi to run as a startup service ?
ok good you fixed it
Did you activate that service?
or whatever filename you created?
https://www.debugpoint.com/2020/12/syst ... l-service/
sudo systemctl enable ombi.service
