pivpn odroidn2+ Topic is solved
Re: pivpn odroidn2+
Reindier wrote: Sun Feb 07, 2021 3:44 pm i run it on my raspberry pi 4 b yesterday and it worked... no problems at all so its got something to do with odoid?
thnx for your help
did you installed 32bit or 64bit on your RPi4B?
Reindier
Re: pivpn odroidn2+
Post by Reindier »
that almost worked for me:
the apt install --reinstall did not find any install on my system
i used apt install openvpn
then:
git clone https://github.com/pivpn/pivpn.git
bash pivpn/auto_install/install.sh
now it works!
thanks for your help
Re: pivpn odroidn2+
ok you installed PiVPN outside dietpi-software now. But should work same way now
amabirts
Re: pivpn odroidn2+
Post by amabirts »
Since updating to v6.43.3 I’ve had constant issues. Firstly using eMMC downloading from Dietpi gives image of v6.28 which works fine. It then updates to latest and fails to reboot.
So I’ve had to use SD card, which boots - slowly - and isn’t stable.
I’ve tried reinstalling both PiVPN and WireGuard in and out of dietpi-software and it is impossible to open.
I’ve never had such issues with Dietpi before. I’ve spend hours trying different solutions but no change... there must be a fundamental issue.
