/usr/local/bin/node-red -u /mnt/dietpi_userdata/node-red
yes. zigbee2mqtt installation instructions are:
dietpi-software
first and check if Zigbee is able to install. Just don't install nodejs as reqjuested in Zigbee install guide. Btw, git as available via dietpi-software
as wellNode-Red is not providing node.js. This is an own software package (ID 9)
how do we use git from Dietpi?Joulinar wrote: ↑Tue Jan 26, 2021 1:38 am you could try to install node.js fromdietpi-software
first and check if Zigbee is able to install. Just don't install nodejs as reqjuested in Zigbee install guide. Btw, git as available viadietpi-software
as well
DietPi is installing node.js directly from https://nodejs.org/dist/
Latest version is 15
git
via dietpi-software
