Cannot launch htop from desktop or others shortcuts Topic is solved
cmoulliard
Re: Cannot launch htop from desktop or others shortcuts
Post by cmoulliard »
What is your config for the following parameters defined within the dietpi.txt file ?
Here are mine
# VNC Server
SOFTWARE_VNCSERVER_WIDTH=1280
SOFTWARE_VNCSERVER_HEIGHT=720
SOFTWARE_VNCSERVER_DEPTH=16
SOFTWARE_VNCSERVER_DISPLAY_INDEX=1
SOFTWARE_VNCSERVER_SHARE_DESKTOP=0
it's default settings. I did not modified anything on these values.
cmoulliard
Using mate looks better as you can see hereafter
BUG: I have discovered an issue. When we switch to another desktop (xfce to mate by example), then the file "/root/.vnc/xstartup" is not updated and by consequence the command executed is still the previous "exec xfce4-session" and not "exec mate-session"
well it's not really a bug. The file /root/.vnc/xstartup is touched during VNC server installations only and not during desktop installation. Therefore it stay unchanged if you change desktop only.
https://github.com/MichaIng/DietPi/blob ... 9770-L9807
Probably some enhancement to check during desktop installation for the availability of /root/.vnc/xstartup and inject the actual desktop
@MichaIng
your thoughts as maintainer :)
Makes sense. We could also use startx to use the system default :?.
hmm startx doesn't seems to be working.
Ah lol of course it cannot work since it wants to start an X server where this is already started as part of the VNC server. Okay, at least we might be able to start the same X client that startx starts.
