PiVPN with Wireguard and PiHole not working correctly Topic is solved
nilsacht
Re: PiVPN with Wireguard and PiHole not working correctly
Post by nilsacht »
So here are my files. First befor vpn connection:
ip -4 addr
http://sprunge.us/6tn5bH
ip -4 ro li table all
http://sprunge.us/QA1EPD
ip -4 ru
http://sprunge.us/fZoLwb
iptables-save -c
http://sprunge.us/d8TiGK
ss -tulnp
http://sprunge.us/AUVUD1
_____________________
And with vpn connection:
ip -4 addr
http://sprunge.us/o06sJ4
http://sprunge.us/bXoqIg
ip -4 ru
http://sprunge.us/4TE6AI
iptables-save -c
http://sprunge.us/8lwXN1
ss -tulnp
http://sprunge.us/yhU2zi
______________________
Hope that helps.
trendy
Post by trendy »
There are some docker entries in the iptables.
Check what @Joulinar wrote here
Other than that there are no differences in routing/rules/iptables/sockets.
nilsacht
Post by nilsacht »
There is no path called
/etc/docker/
on my system. I uninstalled docker with dietpi-software. How can I delete the entries?
trendy
Post by trendy »
Try to reboot. That will start fresh without any leftovers from uninstalled software.
yes docker is a bad guy if you are running it on a VPN server, I was running into that trap as well personally. It's easy to fix but hard to find.
That's basically the issue :FORWARD DROP [4972:303171]
But a reboot should fix it and remove leftover from Docker
nilsacht
Post by nilsacht »
So reboot does not help. How do I get ridd of :FORWARD DROP [4972:303171]?
can you share iptables -S
nilsacht
Post by nilsacht »
it still contains all the docker rules. strange. can you share dpkg -l docker*
nilsacht
Post by nilsacht »
