rock64 -> wifi-hotspot -> Unable to locate package hostapt-realtek
smogan71
Re: rock64 -> wifi-hotspot -> Unable to locate package hostapt-realtek
Post by smogan71 »
MichaIng wrote: Thu Jan 14, 2021 9:31 pm Interesting, the package does not contain any service file. Please do the following (can be done from sub shell from the error prompt as well):
Did it, produced a new error:
- Error log: │
│ Job for hostapd.service failed because the control process exited with error code. │
│ See "systemctl status hostapd.service" and "journalctl -xe" for details.
if I do so, system responds:
root@DietPi:~# systemctl status hostapd.service
● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
Loaded: loaded (/etc/systemd/system/hostapd.service; disabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2021-01-15 14:50:11 GMT; 1s ago
Process: 1743 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, sta
tus=1/FAILURE)
and
-- The unit hostapd.service has entered the 'failed' state with result 'exit-code'.
Jan 15 14:50:56 DietPi systemd[1]: Failed to start Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2
/EAP Authenticator.
-- Subject: A start job for unit hostapd.service has failed
8)
pls can you post journalctl -u hostapd
Additionally, try to execute the binary manually from console and see what it tells: hostapd
Probably we should remove the usage of that package completely. The version anyway starts to become ancient (v2.5 compared to v2.7 on Buster and 2.9 on Bullseye) and it is not possible to build a newer version for RTL8188C* chips, at least with the method I know.
... ah nope, v2.6 would work at least: https://github.com/pritambaral/hostapd-rtl871xdrv
But the issue remains that this always only works for a specific hostapd version until someone patches a never version. If Realtek does not manage or want to implement their driver with full support for hostapd into mainline kernel, we probably need to simply warn users who try to install it on those chips (aside of RPi onboard WiFi). There are a few other cases/chips which simply do not support hostapd, so there never was a guarantee.
