unbound install error? Topic is solved
naddel81
Re: unbound install error?
Post by naddel81 »
Logs begin at Mon 2021-01-11 23:26:05 GMT, end at Mon 2021-01-11 23:36:01 GMT
Jan 11 23:32:38 DietPi systemd[1]: Starting Unbound DNS server...
Jan 11 23:32:38 DietPi package-helper[1458]: /var/lib/unbound/root.key does notexist, copying from /usr/share/dns/root.key
Jan 11 23:32:38 DietPi package-helper[1458]: /var/lib/unbound/root.key has content
Jan 11 23:32:38 DietPi package-helper[1458]: success: the anchor is ok
Jan 11 23:32:38 DietPi unbound[1463]: [1610407958] unbound[1463:0] error: can'tbind socket: Address already in use for ::1 port 53
Jan 11 23:32:38 DietPi unbound[1463]: [1610407958] unbound[1463:0] fatal error:could not open ports
Jan 11 23:32:38 DietPi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Jan 11 23:32:38 DietPi systemd[1]: unbound.service: Failed with result 'exit-code'.
Jan 11 23:32:38 DietPi systemd[1]: Failed to start Unbound DNS server.
Jan 11 23:32:38 DietPi systemd[1]: unbound.service: Service RestartSec=100ms expired, scheduling restart.
Jan 11 23:32:38 DietPi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 1.
Jan 11 23:32:38 DietPi systemd[1]: Stopped Unbound DNS server.
--More--
unbound still trying to use the same port as Pihole leading to a port conflict. Usually configuration should be overwritten by dietpi-software
can you post following
ls -la /etc/unbound/unbound.conf.d/
cat /etc/unbound/unbound.conf
naddel81
Post by naddel81 »
root@DietPi:~# ls -la /etc/unbound/unbound.conf.d/
total 24
drwxr-xr-x 2 root root 4096 Jan 11 23:32 .
drwxr-xr-x 3 root root 4096 Jan 11 23:32 ..
-rw-r--r-- 1 root root   32 Jan 11 23:32 dietpi-pihole.conf
-rw-r--r-- 1 root root 1274 Jan 11 23:32 dietpi.conf
-rw-r--r-- 1 root root  302 May 25  2020 qname-minimisation.conf
-rw-r--r-- 1 root root  190 May 25  2020 root-auto-trust-anchor-file.conf
root@DietPi:~# cat /etc/unbound/unbound.conf root@DietPi:~# ls -la /etc/unbound/unbound.conf.d/
cat: invalid option -- 'l'
Try 'cat --help' for more information.
root@DietPi:~# total 24
-bash: total: command not found
root@DietPi:~# drwxr-xr-x 2 root root 4096 Jan 11 23:32 .
-bash: drwxr-xr-x: command not found
root@DietPi:~# drwxr-xr-x 3 root root 4096 Jan 11 23:32 ..
root@DietPi:~# -rw-r--r-- 1 root root   32 Jan 11 23:32 dietpi-pihole.conf
-bash: -rw-r--r--: command not found
root@DietPi:~# -rw-r--r-- 1 root root 1274 Jan 11 23:32 dietpi.conf
root@DietPi:~# -rw-r--r-- 1 root root  302 May 25  2020 qname-minimisation.conf
root@DietPi:~# -rw-r--r-- 1 root root  190 May 25  2020 root-auto-trust-anchor-file.conf
root@DietPi:~# root@DietPi:~# cat /etc/unbound/unbound.conf
-bash: root@DietPi:~#: command not found
looks like some copy past error on the last command and you invoke some more statements ;)
cat /etc/unbound/unbound.conf.d/dietpi.conf
cat /etc/unbound/unbound.conf.d/dietpi-pihole.conf
naddel81
Post by naddel81 »
total 24
# Unbound configuration file for Debian.
# See the unbound.conf(5) man page.
# See /usr/share/doc/unbound/examples/unbound.conf for a commented
# reference config file.
# The following line includes additional configuration files from the
# /etc/unbound/unbound.conf.d directory.
include: "/etc/unbound/unbound.conf.d/*.conf"
pls post content of the other 2 files as well
naddel81
Post by naddel81 »
root@DietPi:~# cat /etc/unbound/unbound.conf.d/dietpi.conf
server:
    verbosity: 0
    interface: 0.0.0.0
    port: 53
    do-ip4: yes
    do-udp: yes
    do-tcp: yes
    do-ip6: yes
    prefer-ip6: no
    root-hints: "/var/lib/unbound/root.hints"
    harden-glue: yes
    harden-large-queries: yes
    harden-dnssec-stripped: yes
    use-caps-for-id: yes
    edns-buffer-size: 1472
    rrset-roundrobin: yes
    cache-min-ttl: 300
    cache-max-ttl: 86400
    serve-expired: yes
    harden-algo-downgrade: yes
    harden-short-bufsize: yes
    hide-identity: yes
    identity: "Server"
    hide-version: yes
    do-daemonize: no
    neg-cache-size: 4M
    qname-minimisation: yes
    minimal-responses: yes
    prefetch: yes
    prefetch-key: yes
    num-threads: 1
    msg-cache-size: 50m
    rrset-cache-size: 100m
    so-reuseport: yes
    so-rcvbuf: 4m
    so-sndbuf: 4m
    unwanted-reply-threshold: 10000
    ratelimit: 1000
    log-queries: no
    log-replies: no
    logfile: ''
    access-control: 0.0.0.0/0 refuse
    access-control: 127.0.0.1 allow
    access-control: 192.168.2.0/24 allow
    private-address: 192.168.0.0/16
    private-address: 169.254.0.0/16
    private-address: 172.16.0.0/12
    private-address: 10.0.0.0/8
    private-address: fd00::/8
    private-address: fe80::/10
root@DietPi:~# cat /etc/unbound/unbound.conf.d/dietpi-pihole.conf
port: 5353
interface: 127.0.0.1
ok pls do following
dietpi-software install 182
once you hit by the error, you have the possibility to Open subshell from the error handle. On the subshell do following
rm -vf /etc/unbound/unbound.conf.d/{dietpi-pihole,pi-hole}.conf
G_CONFIG_INJECT 'port:[[:blank:]]' '	port: 5353' /etc/unbound/unbound.conf.d/dietpi.conf
G_CONFIG_INJECT 'interface:[[:blank:]]' '	interface: 127.0.0.1' /etc/unbound/unbound.conf.d/dietpi.conf
G_CONFIG_INJECT 'verbosity:[[:blank:]]' '	verbosity: 3' /etc/unbound/unbound.conf.d/dietpi.conf
G_CONFIG_INJECT 'log-queries:[[:blank:]]' '	log-queries: yes' /etc/unbound/unbound.conf.d/dietpi.conf
exit the subshell and hit Retry on the error handle
naddel81
Post by naddel81 »
no error shown. should I continue with the pihole unbound guide now?
usually there is no need to follow any guide. dietpi-software should have set everything correctly. Probably the only thing needed to simply save DNS settings again inside PiHole.
Still i recommend following if not done already
BTW: on upcoming release DietPi 6.35, we will adjust unbound configuration to use port 5335 instead 5353. The new config file will be this once released. https://github.com/MichaIng/DietPi/blob ... bound.conf
