Nextcloud on Dietpi v6.34.3 Topic is solved
cktechie
Re: Nextcloud on Dietpi v6.34.3
Post by cktechie »
backed-up only the Files (entire dietpi_userdata - this showed the database files as well) as well as the regular dietpi_backup folder is available
Should I backup the database as well?
usually it should be enough. Not sure if possible but it might be good to test solution working :)
cktechie
Post by cktechie »
I am doing a fresh backup of everything (will take a while) and will give it a go.. and post results here :)
Need to be ready with a working solution before June 1st (hint... Google Photos deadline ;) )
still enough time to get t working :)
cktechie
Post by cktechie »
I tried, and it failed.
1. Should I first install NextCloud on the Fresh Dietpi Install and then Restore
OR
2. Simply restore the backup on Fresh Dietpi install.
Both cases failed. When I go to the Web URL link for NextCloud, I get the error
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.
Looks like the mariadb.service is failing.
- Error log:
Job for mariadb.service failed because the control process exited with error code.
See "systemctl status mariadb.service" and "journalctl -xe" for details.
Tried re-install of mariaDB, but just does not work.
Any help?
Usually first install NC and restore backup afterwards. Can you check if database server is up?
cktechie
Post by cktechie »
- Error log:
Tried re-install of mariaDB, but just does not work. Should I post the error logs?
Yes there is an error log on /var/log/
cktechie
Post by cktechie »
Which one is the exact log file I need to look for?
:/var/log$ ls -l
total 28
-rw-r--r-- 1 root root 0 Jan 11 14:27 Xorg.0.log
-rw-r--r-- 1 root root 0 Jan 11 14:17 Xorg.0.log.old
-rw-r--r-- 1 root root 420 Jan 20 08:38 alternatives.log
drwxr-xr-x 2 root root 100 Jan 20 08:39 apt
-rw-rw---- 1 root utmp 0 Jan 20 08:13 btmp
-rw-r--r-- 1 root root 0 Jan 20 08:11 dietpi-backup.log
-rw-r--r-- 1 root root 0 Dec 29 14:10 dietpi-move_userdata.log
-rw-r--r-- 1 root root 5113 Jan 20 08:39 dpkg.log
-rw-r--r-- 1 root root 0 Jan 5 10:34 fontconfig.log
-rw-rw-r-- 1 root utmp 292292 Jan 20 08:37 lastlog
drwxr-x--- 2 www-data www-data 60 Dec 29 13:28 lighttpd
drwxr-s--- 2 mysql adm 60 Dec 29 13:31 mysql
-rw------- 1 root root 564 Jan 20 08:57 php7.3-fpm.log
drwx------ 2 root root 40 Sep 10 05:33 private
drwxr-s--- 2 redis adm 60 Dec 29 13:32 redis
-rw-rw-r-- 1 root utmp 1152 Jan 20 08:37 wtmp
Inside mysql there should be an error.log
