Problems accessing TasmoAdmin Topic is solved
UsAs
Re: Problems accessing TasmoAdmin
Post by UsAs »
everything pre installed by pihole.
how can i take a look?
UsAs
Post by UsAs »
lighttpd
you can check the LISTEN ports, This will show the web server
ss -tulpn | grep LISTEN
Btw: how did you install PiHole? did you used dietpi-software or something else?
UsAs
Post by UsAs »
yup. used dietpi-software :)
di you have running something like pihole -r in past? And pls check for the LISTEN ports
UsAs
Post by UsAs »
a few month ago i had to repair pihole, yes.
then i had to use -r.
ok that might be the issue. pihole -r will offer 2 options. If you choose wrong one, it will replace DietPi configs with a pure PiHole web server config, leading to such effect. If you are using standard, you should be running lighttpd web server. Pls can you post following
ls -la /etc/lighttpd/
UsAs
Post by UsAs »
sure.
UsAs
Post by UsAs »
i even used tuya-convert today. but i don't know if it's usinf lighttpd.
yep PiHole has overwritten our config file. Try following to fix
cd /etc/lighttpd/
mv lighttpd.conf lighttpd.conf.hole
mv lighttpd.conf.orig lighttpd.conf
systemctl restart lighttpd.service
