How prepare the transition/upgrade from Buster to next version? Topic is solved
mail2rst
Re: How prepare the transition/upgrade from Buster to next version?
Post by mail2rst »
Adguard home web page give this error
Error: control/version.json | Couldn't get version check json from https://static.adguard.com/adguardhome/release/version.json: *fmt.wrapError updater: HTTP GET https://static.adguard.com/adguardhome/release/version.json: Get "https://static.adguard.com/adguardhome/release/version.json": read udp 127.0.0.1:46223->127.0.0.1:5335: read: connection refused | 502
Do the other devices user AdGuard Home for name resolution/ad blocking? Looks like it has an issue to contract the update server.
Does AdGuard Home use Unbound or another local resolver? I see a refused 127.0.0.1:5335 connection. In case check Unbound status:
journalctl -u unbound
mail2rst
Post by mail2rst »
both system show this fail display page.
Raspberry pi running. homeasssitant, valutwarden, mqtt broker, zigbee2mqtt, openssh
nuc running : plex, adguard, unbound, wireguard, openssh
unbound, homeasssistant, adguard are in trouble
valut warden lokks ok, adguard screen show error (may be unbound).
in dietpi-config networg adpter static & dns resolver cloudflare 1.1.1.1
As you can see on your first screen print, there is an issue with Mosquitto as there is no Bullseye repository available yet. This we already discovered and a workaround is described on the link I posted above https://github.com/MichaIng/DietPi/issu ... -877590830
On the 2nd screen the issue is with the repository name for debian-security. On Bullseye it's called bullseye-security at the moment and not just bullseye. /etc/apt/sources.list you would need to adjust as follow
sed -i 's|bullseye/updates|bullseye-security|' /etc/apt/sources.list
mail2rst
Post by mail2rst »
Thanks @Joulinar & @MichaIng With your given hints, I am able to troubleshoot both my machines. I confirm that both my machine migrated to bullseye from buster. All my software works same way no change
Raspbeerry pi B2 > Homeasssistant, MQTT, zigbee2mqtt, valutwarden, openssh
NUC AMD64 > plex, adguard home , unbound 1.13, wireguard, openssh
Thanks for your hard work & expert advises every time.
thx for sharing. Don't forget to switch Mosquitto to Bullseye once they added the repository. You can watch the repo https://repo.mosquitto.org/debian/dists/
