Odroid HC4 sata drives not recognized
BitWise
Re: Odroid HC4 sata drives not recognized
Post by BitWise »
The if statement is present in dietpi boot.ini, no sata recognized. Redownloaded image to confirm, and got the same results. Meveric image sata recognized before update, but not after update and reboot.
That is a good hint, thanks for testing and feedback, so then the kernel update broke SATA.
@BitWise
Which SATA drive are you using? And if you have the DietPi SD card still at hand, could you check for some kernel messages and how much of the drive or controller is detected at all?
dmesg
fdisk -l
apt install lspci
lspci -t
BitWise
Post by BitWise »
Sata Drive is Western Digital WD Blue 6TB, model WD60EZAZ.
root@DietPi:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.236-arm64 (root@odroid-stretch64) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT Wed Nov 11 22:54:44 CET 2020
[    0.000000] Boot CPU: AArch64 Processor [411fd050]
[    0.000000] Machine model: Hardkernel ODROID-HC4
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000]  07400000 - 07500000,     1024 KB, ramoops@0x07400000
[    0.000000] __reserved_mem_alloc_size, start:0x0000000005000000, end:0x0000000005400000, len:4 MiB
[    0.000000]  05000000 - 05400000,     4096 KB, linux,secmon
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ed800000, size 0 MiB
[    0.000000]  ed800000 - ed800000,        0 KB, linux,ppmgr
[    0.000000] __reserved_mem_alloc_size, start:0x000000007f800000, end:0x0000000080000000, len:8 MiB
[    0.000000]  7f800000 - 80000000,     8192 KB, linux,meson-fb
[    0.000000]  e5800000 - ed800000,   131072 KB, linux,ion-dev
[    0.000000]  e3000000 - e5800000,    40960 KB, linux,di_cma
[    0.000000]  cfc00000 - e3000000,   315392 KB, linux,codec_mm_cma
[    0.000000]  cfc00000 - cfc00000,        0 KB, linux,codec_mm_reserved
[    0.000000] cma: Reserved 8 MiB at 0x00000000cf400000
[    0.000000] On node 0 totalpages: 972800
[    0.000000]   DMA zone: 15200 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 972800 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 21 pages/cpu s47960 r8192 d29864 u86016
[    0.000000] pcpu-alloc: s47960 r8192 d29864 u86016 alloc=21*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 957600
[    0.000000] Kernel command line: root=/dev/mmcblk1p2 rootwait ro console=ttyS0,115200n8  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a55= maxcpus=4 voutmode=hdmi  disablehpd=false cvbscable=0  overscan=100  monitor_onoff=false logo=osd0,loaded  sdrmode=auto enable_wol=0
[    0.000000] vout: get hdmimode: 1080p60hz
[    0.000000] vout: get cvbsmode: 576cvbs
[    0.000000] hdmitx: voutmode : 1
[    0.000000] fb: osd0
[    0.000000] fb: loaded
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3280732K/3891200K available (11964K kernel code, 1760K rwdata, 5164K rodata, 4928K init, 1412K bss, 102564K reserved, 507904K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8009080000 - 0xffffff8009c30000   ( 11968 KB)
[    0.000000]     .rodata : 0xffffff8009c30000 - 0xffffff800a140000   (  5184 KB)
[    0.000000]       .init : 0xffffff800a140000 - 0xffffff800a610000   (  4928 KB)
[    0.000000]       .data : 0xffffff800a610000 - 0xffffff800a7c8200   (  1761 KB)
[    0.000000]        .bss : 0xffffff800a7c8200 - 0xffffff800a92953c   (  1413 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03b60000   (    59 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ed800000   (  3800 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GPIO-INTC: support to detect double-edge trigger signal
[    0.000000] g12a_aoclkc_init: register ao clk ok!
[    0.000000] Meson chip version = RevC (2B:C - 10:0)
[    0.000000] meson_g12a_sdemmc_init: register amlogic sdemmc clk
[    0.000000] meson_g12a_gpu_init: register meson gpu clk
[    0.000000] meson_g12a_media_init: register meson media clk
[    0.000000] meson_g12a_misc_init: register amlogic g12a misc clks
[    0.000000] meson_g12a_misc_init: done.
[    0.000000] g12a_clkc_init initialization complete
[    0.000000] sm1 clk probe ok
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000020] meson_bc_timer: mclk->mux_reg =ffffff800800c190,mclk->reg =ffffff800800e194
[    0.000270] Console: colour dummy device 80x25
[    0.000281] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000286] pid_max: default: 32768 minimum: 301
[    0.000345] Security Framework initialized
[    0.000362] AppArmor: AppArmor initialized
[    0.000380] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.000385] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.000767] ftrace: allocating 39777 entries in 156 pages
[    0.039692] sched-energy: CPU device node has no sched-energy-costs
[    0.039701] CPU0: update cpu_capacity 1024
[    0.039710] ASID allocator initialised with 65536 entries
[    0.078800] secmon: can't fine clear_range
[    0.079179] EFI services will not be available.
[    0.124058] Detected VIPT I-cache on CPU1
[    0.124094] CPU1: update cpu_capacity 1024
[    0.124096] CPU1: Booted secondary processor [411fd050]
[    0.156095] Detected VIPT I-cache on CPU2
[    0.156120] CPU2: update cpu_capacity 1024
[    0.156122] CPU2: Booted secondary processor [411fd050]
[    0.188146] Detected VIPT I-cache on CPU3
[    0.188167] CPU3: update cpu_capacity 1024
[    0.188168] CPU3: Booted secondary processor [411fd050]
[    0.188221] Brought up 4 CPUs
[    0.188237] SMP: Total of 4 processors activated.
[    0.188240] CPU features: detected feature: Privileged Access Never
[    0.188243] CPU features: detected feature: User Access Override
[    0.188246] CPU features: detected feature: 32-bit EL0 Support
[    0.188342] CPU: All CPU(s) started at EL2
[    0.188354] alternatives: patching kernel code
[    0.189757] devtmpfs: initialized
[    0.200398] DMI not present or invalid.
[    0.200600] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.200609] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.200730] pinctrl core: initialized pinctrl subsystem
[    0.201209] NET: Registered protocol family 16
[    0.201844] schedtune: init normalization constants...
[    0.201848] schedtune: no energy model data
[    0.201850] schedtune: disabled!
[    0.211897] cpuidle: using governor menu
[    0.211956] register canvas platform driver
[    0.211978] register rdma platform driver
[    0.212671] vdso: 2 pages (1 code @ ffffff8009c37000, 1 data @ ffffff800a615000)
[    0.212680] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.213453] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.213573] clkmsr: clkmsr: driver init
[    0.213577] codec_mm_module_init
[    0.213592] media_configs_system_init
[    0.214329] pstore: using zlib compression
[    0.214571] console [pstore-1] enabled
[    0.214575] pstore: Registered ramoops as persistent store backend
[    0.214579] ramoops: attached 0x100000@0x7400000, ecc: 0/0
[    0.215547] aml_iomap: amlogic iomap probe done
[    0.215805] vpu: driver version: v20190329(10-sm1)
[    0.215813] vpu: load vpu_clk: 666666667Hz(7)
[    0.215955] vpu: clktree_init
[    0.215991] vpu: vpu_probe OK
[    0.218522] clkmsr: msr_clk_reg0=ffffff8008453004,msr_clk_reg2=ffffff800845500c
[    0.218535] clkmsr: msr_ring_reg0=ffffff80084575fc
[    0.220251] audio_clocks: audio_clocks_probe done
[    0.220791] aml_snd_reg_map[0], reg:ff661000, size:400
[    0.220804] aml_snd_reg_map[1], reg:ff660000, size:1000
[    0.220813] aml_snd_reg_map[2], reg:ff661400, size:400
[    0.220822] aml_snd_reg_map[3], reg:ff662000, size:1000
[    0.220830] aml_snd_reg_map[4], reg:ffd01000, size:1000
[    0.220838] aml_snd_reg_map[5], reg:ff661800, size:400
[    0.220847] aml_snd_reg_map[6], reg:ff661c00, size:104
[    0.220855] aml_snd_reg_map[7], reg:ff664000, size:104
[    0.220859] amlogic auge_snd_iomap probe done
[    0.221708] aml_vdac_config_probe: cpu_id:6, name:meson-sm1-vdac
[    0.221826] aml_vdac_probe: ok
[    0.221905] canvas_probe reg=00000000ff638000,size=2000
[    0.221918] canvas maped reg_base =ffffff800846c000
[    0.225032] rdma_probe,cpu_type:1, ver:0, len:8
[    0.225188] rdma_register, rdma_table_addr ffffff80084a1000 rdma_table_addr_phy cf600000 reg_buf ffffffc0ca1d8000
[    0.225196] rdma_register success, handle 1 table_size 32768
[    0.225200] set_rdma_handle video rdma handle = 1.
[    0.225220] classs created ok
[    0.225229] classs file created ok
[    0.226189] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[    0.226269] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[    0.226275] codec_mm_probe ok
[    0.226701] cvbs_out: cvbsout_probe, cpu_id:7,name:meson-sm1-cvbsout
[    0.226712] cvbs_out: clk path:0
[    0.226716] cvbs_out: error: failed to get vdac_config
[    0.226817] vout: vout1: register server: cvbs_vout_server
[    0.226822] cvbs_out: register cvbs module server ok
[    0.226826] vout: vout2: register server: cvbs_vout2_server
[    0.226829] cvbs_out: register cvbs module vout2 server ok
[    0.226834] cvbs_out: chrdev devno 264241152 for disp
[    0.226954] cvbs_out: create cdev cvbs
[    0.226959] cvbs_out: cvbsout_probe OK
[    0.329900] SCSI subsystem initialized
[    0.330062] usbcore: registered new interface driver usbfs
[    0.330100] usbcore: registered new interface driver hub
[    0.330148] usbcore: registered new device driver usb
[    0.330231] media: Linux media interface: v0.10
[    0.330265] Linux video capture interface: v2.00
[    0.330334] pps_core: LinuxPPS API ver. 1 registered
[    0.330339] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.330356] PTP clock support registered
[    0.330456] dmi: Firmware registration failed.
[    0.330688] secmon: reserve_mem_size:0x300000
[    0.330755] secmon secmon: assigned reserved memory node linux,secmon
[    0.330909] secmon: get page:ffffffbf00140000, 5000
[    0.330916] secmon: share in base: 0xffffffc0050fe000, share out base: 0xffffffc0050ff000
[    0.330920] secmon: phy_in_base: 0x50fe000, phy_out_base: 0x50ff000
[    0.331385] hdmitx: system: amhdmitx_probe start
[    0.331390] hdmitx: system: Ver: 20190815
[    0.331413] hdmitx: system: hdmitx_device.chip_type : 12
[    0.331443] hdmitx: system: not find match pwr-ctl
[    0.331481] hdmitx: system: not find drm_amhdmitx
[    0.331498] hdmitx: system: hpd irq = 43
[    0.331566] hdmitx: system: hdcp22_tx_skp failed to probe
[    0.331570] hdmitx: system: hdcp22_tx_esm failed to probe
[    0.331827] vout: vout1: register server: hdmitx_vout_server
[    0.331833] vout: vout2: register server: hdmitx_vout2_server
[    0.332147] hdmitx: hdmitx20: Mapped PHY: 0xffd00000
[    0.332162] hdmitx: hdmitx20: Mapped PHY: 0xff634400
[    0.332169] hdmitx: hdmitx20: Mapped PHY: 0xff900000
[    0.332180] hdmitx: hdmitx20: Mapped PHY: 0xff800000
[    0.332187] hdmitx: hdmitx20: Mapped PHY: 0xff63c000
[    0.332191] hdmitx: hdmitx20: Mapped PHY: 0xffd00000
[    0.332195] hdmitx: hdmitx20: Mapped PHY: 0xff608000
[    0.332199] hdmitx: hdmitx20: Mapped PHY: 0xff600000
[    0.332207] hdmitx: hdmitx20: Mapped PHY: 0xffe01000
[    0.332215] hdmitx: hw: hdmitx_get_format:0x4
[    0.332218] hdmitx: hw: P_HHI_HDMI_CLK_CNTL :0x10100
[    0.332221] hdmitx: hw: P_HHI_HDMI_PLL_CNTL :0x2b0604f7
[    0.332447] hdmitx: hw: avmute set to 1
[    0.332453] hdmitx: system: fmt_attr default
[    0.332505] hdmitx: system: amhdmitx_probe end
[    0.332748] vout: create vout attribute OK
[    0.332862] vout: vout_fops_create OK
[    0.332869] vout: vout1: register server: nulldisp_vout_server
[    0.332948] vout: tvout monitor interval:500(ms), timeout cnt:20
[    0.332967] hdmitx: hdmitx_set_current_vmode[3877]
[    0.332971] hdmitx: system: recalc before 1080p60hz 60 1
[    0.332976] hdmitx: system: recalc after 1080p60hz 2997 50
[    0.332979] hdmitx: alread display in uboot
[    0.332983] vout: init mode 1080p60hz set ok
[    0.332986] vout: aml_tvout_mode_monitor
[    0.332995] vout: aml_vout_probe OK
[    0.333392] amlogic-pcie-v2 fc000000.pcieA: amlogic_pcie_probe!
[    0.335869] OF: PCI: host bridge /pcieA@fc000000 ranges:
[    0.335882] OF: PCI:    IO 0xfc600000..0xfc6fffff -> 0x00000000
[    0.335890] OF: PCI:   MEM 0xfc700000..0xfdffffff -> 0xfc700000
[    0.336351] amlogic-pcie-v2 fc000000.pcieA: Set the RC Bus Master, Memory Space and I/O Space enables.
[    0.336357] amlogic-pcie-v2 fc000000.pcieA: normal gpio
[    0.336402] amlogic-pcie-v2 fc000000.pcieA: GPIO normal: amlogic_pcie_assert_reset
[    0.369039] amlogic-pcie-v2 fc000000.pcieA: PCIE SPEED IS GEN2
[    0.369045] amlogic-pcie-v2 fc000000.pcieA: link up
[    0.369147] amlogic-pcie-v2 fc000000.pcieA: PCI host bridge to bus 0000:00
[    0.369155] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.369160] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff]
[    0.369165] pci_bus 0000:00: root bus resource [mem 0xfc700000-0xfdffffff]
[    0.369170] pci_bus 0000:00: scanning bus
[    0.369184] amlogic-pcie-v2 fc000000.pcieA: the device class is not reported correctly from the register
[    0.369190] pci 0000:00:00.0: [16c3:abcd] type 01 class 0x060400
[    0.369207] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[    0.369239] pci 0000:00:00.0: supports D1
[    0.369241] pci 0000:00:00.0: PME# supported from D0 D1 D3hot D3cold
[    0.369245] pci 0000:00:00.0: PME# disabled
[    0.369345] pci_bus 0000:00: fixups for bus
[    0.369349] pci 0000:00:00.0: scanning [bus 01-ff] behind bridge, pass 0
[    0.369398] pci_bus 0000:01: scanning bus
[    0.369453] pci 0000:01:00.0: [1b21:0611] type 00 class 0x010185
[    0.369504] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x0007]
[    0.369529] pci 0000:01:00.0: reg 0x14: [io  0x0000-0x0003]
[    0.369555] pci 0000:01:00.0: reg 0x18: [io  0x0000-0x0007]
[    0.369580] pci 0000:01:00.0: reg 0x1c: [io  0x0000-0x0003]
[    0.369606] pci 0000:01:00.0: reg 0x20: [io  0x0000-0x000f]
[    0.369631] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
[    0.369657] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    0.369688] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    0.369957] pci_bus 0000:01: fixups for bus
[    0.369960] pci_bus 0000:01: bus scan returning with max=01
[    0.369965] pci 0000:00:00.0: scanning [bus 01-ff] behind bridge, pass 1
[    0.369969] pci_bus 0000:00: bus scan returning with max=ff
[    0.369985] pci 0000:00:00.0: BAR 8: assigned [mem 0xfc700000-0xfc7fffff]
[    0.369992] pci 0000:00:00.0: BAR 9: assigned [mem 0xfc800000-0xfc8fffff pref]
[    0.369997] pci 0000:00:00.0: BAR 6: assigned [mem 0xfc900000-0xfc90ffff pref]
[    0.370003] pci 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
[    0.370011] pci 0000:01:00.0: BAR 6: assigned [mem 0xfc800000-0xfc80ffff pref]
[    0.370016] pci 0000:01:00.0: BAR 5: assigned [mem 0xfc700000-0xfc7001ff]
[    0.370032] pci 0000:01:00.0: BAR 4: assigned [io  0x1000-0x100f]
[    0.370047] pci 0000:01:00.0: BAR 0: assigned [io  0x1010-0x1017]
[    0.370061] pci 0000:01:00.0: BAR 2: assigned [io  0x1018-0x101f]
[    0.370076] pci 0000:01:00.0: BAR 1: assigned [io  0x1020-0x1023]
[    0.370090] pci 0000:01:00.0: BAR 3: assigned [io  0x1024-0x1027]
[    0.370105] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    0.370111] pci 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[    0.370117] pci 0000:00:00.0:   bridge window [mem 0xfc700000-0xfc7fffff]
[    0.370122] pci 0000:00:00.0:   bridge window [mem 0xfc800000-0xfc8fffff pref]
[    0.370341] chip type:0x2b
[    0.370558] MEMORY:[0+ed800000]
[    0.370564] ramdump_probe, storage device:data
[    0.370568] NO valid ramdump args:0 0
[    0.370579] ramdump_probe, set sticky to 8ed8
[    0.370700] Advanced Linux Sound Architecture Driver Initialized.
[    0.371259] NetLabel: Initializing
[    0.371268] NetLabel:  domain hash size = 128
[    0.371271] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.371300] NetLabel:  unlabeled traffic allowed by default
[    0.372121] clocksource: Switched to clocksource arch_sys_counter
[    0.412844] VFS: Disk quotas dquot_6.6.0
[    0.412916] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.413095] AppArmor: AppArmor Filesystem Enabled
[    0.422531] NET: Registered protocol family 2
[    0.423051] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.423195] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.423693] TCP: Hash tables configured (established 32768 bind 32768)
[    0.423783] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.423824] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.424008] NET: Registered protocol family 1
[    0.424070] PCI: CLS 0 bytes, default 64
[    0.425907] Unpacking initramfs...
[    0.629110] Freeing initrd memory: 7816K
[    0.638915] hw perfevents: clusterb_enabled = 0
[    0.638939] hw perfevents: cpumasks 0xf, 0x0
[    0.638976] hw perfevents: cluster A irq = 18
[    0.639056] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.641663] audit: initializing netlink subsys (disabled)
[    0.641753] audit: type=2000 audit(0.608:1): initialized
[    0.642512] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.648664] Registering sdcardfs 0.1
[    0.652800] NET: Registered protocol family 38
[    0.652830] Key type asymmetric registered
[    0.652837] Asymmetric key parser 'x509' registered
[    0.653073] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.653088] io scheduler noop registered (default)
[    0.653094] io scheduler deadline registered
[    0.653237] io scheduler cfq registered
[    0.654060] amlogic-pcie-v2 fc000000.pcieA: the device class is not reported correctly from the register
[    0.654255] aer 0000:00:00.0:pcie002: service driver aer loaded
[    0.654309] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    0.654321] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    0.654328] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[    0.656034] meson-pwm ff802000.pwm: pwm pinmux : can't get pinctrl
[    0.657064] random: fast init done
[    0.657117] random: crng init done
[    0.657456] gpiomem-aml ff634000.gpiomem: Initialised: GPIO register area is 2
[    0.657645] gpiomem-aml ff634000.gpiomem: Initialised: Registers at start:0xff634000 end:0xff634fff size:0x00000fff
[    0.657655] gpiomem-aml ff634000.gpiomem: Initialised: Registers at start:0xff800000 end:0xff800fff size:0x00000fff
[    0.657780] [drm] Initialized
[    0.657890] mali ffe40000.bifrost: Continuing without Mali regulator control
[    0.658033] mali ffe40000.bifrost: max pp is 2
[    0.658041] mali ffe40000.bifrost: set min pp to default 1
[    0.658046] mali ffe40000.bifrost: min pp is 1
[    0.658053] mali ffe40000.bifrost: min clk  is 4
[    0.658077] mali ffe40000.bifrost: hiu io source  0xffffff80084e5000
[    0.658085] mali ffe40000.bifrost: hiu io source  0xffffff80084e7000
[    0.658090] mali ffe40000.bifrost: num of pp used most of time 1
[    0.658096] mali ffe40000.bifrost: clock dvfs cfg table size is 6
[    0.658238] mali ffe40000.bifrost: max clk set 4
[    0.658244] mali ffe40000.bifrost: max clk  is 4
[    0.658250] mali ffe40000.bifrost: turbo clk set to 5
[    0.658255] mali ffe40000.bifrost: turbo clk  is 5
[    0.658260] mali ffe40000.bifrost: default clk set to 4
[    0.658265] mali ffe40000.bifrost: default clk  is 4
[    0.658272] mali ffe40000.bifrost: ====================0====================
               clk_freq= 285714285, clk_parent=fclk_div7, voltage=1150, keep_count=5, threshod=<100 190>, clk_sample=285
[    0.658281] mali ffe40000.bifrost: ====================1====================
               clk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_count=5, threshod=<152 207>, clk_sample=400
[    0.658289] mali ffe40000.bifrost: ====================2====================
               clk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, threshod=<180 220>, clk_sample=500
[    0.658297] mali ffe40000.bifrost: ====================3====================
               clk_freq= 666666666, clk_parent=fclk_div3, voltage=1150, keep_count=5, threshod=<210 236>, clk_sample=666
[    0.658305] mali ffe40000.bifrost: ====================4====================
               clk_freq= 846000000, clk_parent=  gp0_pll, voltage=1150, keep_count=5, threshod=<230 255>, clk_sample=846
[    0.658313] mali ffe40000.bifrost: ====================5====================
[    0.658320] mali ffe40000.bifrost: clock dvfs table size is 6
[    0.659801] mali_plat=ffffff800a6a0018
[    0.659958] meson_gcooldev is null, no set min status
[    0.659967] gpu cooling register okay with err=0
[    0.660029] meson_gcooldev is null, no set min status
[    0.660036] gpu core cooling register okay with err=0
[    0.660069] shader_present=1, tiler_present=1, l2_present=1
[    0.660166] Mali_pwr_on:gpu_irq : 200
[    0.660426] mali ffe40000.bifrost: GPU identified as 0x3 arch 7.0.9 r0p0 status 0
[    0.661718] mali ffe40000.bifrost: Probed as mali0
[    0.662131] Unable to detect cache hierarchy for CPU 0
[    0.666558] loop: module loaded
[    0.667025] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.667566] libphy: Fixed MDIO Bus: probed
[    0.668422]  REG0:Addr = ffffff80084eb540
[    0.668445]  ee eth reset:Addr = ffffff80084ed008
[    0.668454] read auto_cali_idx fail
[    0.668461] Not set  cali_val for REG1
[    0.668935] meson6-dwmac ff3f0000.ethernet: no reset control found
[    0.668946] stmmac - user ID: 0x11, Synopsys ID: 0x37
[    0.668952]  Ring mode enabled
[    0.668958]  DMA HW capability register supported
[    0.668963]  Normal descriptors
[    0.668968]  RX Checksum Offload Engine supported
[    0.668972]  COE Type 2
[    0.668975]  TX Checksum insertion supported
[    0.668979]  Wake-Up On Lan supported
[    0.669017] eth%d: device MAC address 00:1e:06:49:02:35
[    0.669022]  Enable RX Mitigation via HW Watchdog Timer
[    0.685791] libphy: stmmac: probed
[    0.685819] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    0.685825] eth%d: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07)
[    0.687611] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.687634] ehci-pci: EHCI PCI platform driver
[    0.687751] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.688403] usbcore: registered new interface driver cdc_acm
[    0.688419] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.688484] usbcore: registered new interface driver usb-storage
[    0.688620] usbcore: registered new interface driver usbserial
[    0.688672] usbcore: registered new interface driver usbserial_generic
[    0.688701] usbserial: USB Serial support registered for generic
[    0.689129] mousedev: PS/2 mouse device common for all mice
[    0.689463] i2c /dev entries driver
[    0.691528] lirc_helper: wakeupkey 0xffffffff, protocol 0x1
[    0.692504] device-mapper: uevent: version 1.0.3
[    0.692822] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    0.694787] ledtrig-cpu: registered to indicate activity on CPUs
[    0.695270] hidraw: raw HID events driver (C) Jiri Kosina
[    0.695629] usbcore: registered new interface driver usbhid
[    0.695642] usbhid: USB HID core driver
[    0.696414] value of voltage_tolerance 0
[    0.696431] meson_cpufreq_init:don't find the node <dynamic_gp1_clk>
[    0.696435] value of gp1_clk_target 0
[    0.697174] dvfs [meson_cpufreq_init] - cluster 0 freq 1908000
[    0.697181] dvfs [meson_cpufreq_init] - cluster 0 freq 2016000
[    0.697187] dvfs [meson_cpufreq_init] - cluster 0 freq 2100000
[    0.697206] cpu cpu0: meson_cpufreq_init: CPU 0 initialized
[    0.697239] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 2100000 KHz
[    0.700278] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1800000 KHz
[    0.700679] ff803000.serial: clock gate not found
[    0.700740] meson_uart ff803000.serial: ==uart0 reg addr = ffffff80084f3000
[    0.700794] ff803000.serial: ttyS0 at MMIO 0xff803000 (irq = 30, base_baud = 1500000) is a meson_uart
[    0.700811] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 0 to 115200
[    0.991897] clear:c5000000, free:c5000000, tick:598699 us
[    2.887026] console [ttyS0] enabled
[    2.891737] meson_uart ffd24000.serial: ==uart1 reg addr = ffffff80084f5000
[    2.897792] ffd24000.serial: ttyS1 at MMIO 0xffd24000 (irq = 41, base_baud = 1500000) is a meson_uart
[    2.908595] amlogic-new-usb2-v2 ffe09000.usb2phy: USB2 phy probe:phy_mem:0xffe09000, iomap phy_base:0xffffff80084f7000
[    2.919378] aml_dma ff63e000.aml_dma: Aml dma
[    2.924171] aml_aes_dma ff63e000.aml_dma:aml_aes: Aml AES_dma
[    2.931231] aml_sha_dma ff63e000.aml_dma:aml_sha: Aml SHA1/SHA224/SHA256 dma
[    2.935737] gpio-keypad: probe of ff800000.gpio_keypad failed with error -22
[    2.943036] efusekeynum: 1
[    2.945621] efusekeyname:            uuid    offset:     0   size:    32
[    2.952604] efuse efuse: probe OK!
[    2.961348] ion_dev soc:ion_dev: assigned reserved memory node linux,ion-dev
[    2.964600] ge2d: ge2d_init_module
[    2.966669] ge2d: ge2d_dev major:236
[    2.970870] ge2d: clock source clk_ge2d_gate ffffffc0ca144380
[    2.976170] ge2d: clock clk_ge2d source ffffffc0ca144a40
[    2.981580] ge2d: clock source clk_vapb_0 ffffffc0ca144200
[    2.987200] ge2d: ge2d init clock is 500000000 HZ, VPU clock is 666666656 HZ
[    2.994493] ge2d: ge2d clock is 499 MHZ
[    2.998392] ge2d: find address resource
[    3.002373] ge2d: map io source 0x00000000ff940000,size=65536 to 0xffffff80086b0000
[    3.010170] ge2d: reserved mem init failed
[    3.014412] ge2d: ge2d: pdev=ffffffc0ca199c00, irq=47, clk=ffffffc0ca144380
[    3.021554] ge2d: ge2d start monitor
[    3.025607] ge2d: ge2d workqueue monitor start
[    3.025909] [tsync_pcr_init]init success.
[    3.026075] amvideom vsync irq: 48
[    3.026097] create_ge2d_work_queue video task ok
[    3.026603] fb: osd_init_module
[    3.026959] fb: viu vsync irq: 48
[    3.026967] fb: viu2 vsync irq: 64
[    3.027041] 0x000000db:Y=db,U=0,V=0
[    3.027042] 0x000000dc:Y=dc,U=0,V=0
[    3.027044] 0x000000dd:Y=dd,U=0,V=0
[    3.027045] 0x000000de:Y=de,U=0,V=0
[    3.027046] 0x000000df:Y=df,U=0,V=0
[    3.027047] 0x000000e0:Y=e0,U=0,V=0
[    3.029957] fb: osd_rdma_init: rdma_table p=0xcf608000,op=0xcf608000 , v=0xffffff8008607000
[    3.029986] rdma_register, rdma_table_addr ffffff8008609000 rdma_table_addr_phy cf609000 reg_buf ffffffc0c9f1c000
[    3.029988] rdma_register success, handle 2 table_size 4096
[    3.029989] fb: osd_rdma_init:osd rdma handle = 2.
[    3.029998] fb: mem_size: 0x800000
[    3.029999] fb: mem_size: 0x4b80000
[    3.030000] fb: mem_size: 0x100000
[    3.030001] fb: mem_size: 0x100000
[    3.030001] fb: mem_size: 0x800000
[    3.030004] fb: failed to init reserved memory
[    3.030013] fb: fb def : 1920 1080 1920 2160 32
[    3.030014] fb: init fbdev bpp is:32
[    3.134898] fb: malloc_osd_memory, cma:ffffff800a883b30
[    3.134901] fb: malloc_osd_memory, 1231, base:0x00000000cf400000, size:8388608
[    3.134916] fb: use ion buffer for fb memory, fb_index=0
[    3.134918] fb: OSD0 as afbcd mode,afbc_type=2
[    3.155453] meson-fb meson-fb: create ion_client ffffffc0ca161f00, handle=ffffffc0c9e82b80
[    3.155458] meson-fb meson-fb: ion memory(0): created fb at 0x00000000e5800000, size 75 MiB
[    3.155461] fb:  0, phy: 0x00000000e5800000, vir:0xffffff800ad01000, size=77312K
[    3.155465] fb: Frame buffer memory assigned at
[    3.155465] fb:  0, phy: 0x00000000e5800000, vir:0xffffff800ad01000, size=77312K
[    3.155467] fb:  0, phy: 0x00000000e5800000, vir:0xffffff800ad01000, size=77312K
[    3.155468] fb: logo_index=0,fb_index=0
[    3.155470] fb: ---------------clear fb0 memory ffffff800ad01000
[    3.171314] fb: osd[0] canvas.idx =0x40
[    3.171315] fb: osd[0] canvas.addr=0xe5800000
[    3.171316] fb: osd[0] canvas.width=7680
[    3.171317] fb: osd[0] canvas.height=2160
[    3.171318] fb: osd[0] frame.width=1920
[    3.171319] fb: osd[0] frame.height=1080
[    3.171320] fb: osd[0] out_addr_id =0x1
[    5.226987] Console: switching to colour frame buffer device 240x67
[    6.364140] fb: osd[0] enable: 1 (swapper/0)
[    7.388696] fb: set osd0 reverse as NONE
[    8.412406] fb: osd probe OK
[    8.412518] hdmitx: hdcp: hdmitx_hdcp_init
[    8.414974] vout: vout2: create vout2 attribute OK
[    8.419133] vout: vout2: vout2_fops_create OK
[    8.423727] vout: vout2: clktree_init
[    8.427338] vout: vout2: register server: nulldisp_vout2_server
[    8.433493] vout: vout2: init mode null set ok
[    8.437996] vout: vout2: aml_vout2_probe OK
[    8.442438] DI: di_module_init ok.
[    8.446053] DI: di_probe:
[    8.448664] DI: di_probe: major 510
[    8.452472] deinterlace deinterlace: assigned reserved memory node linux,di_cma
[    8.459779] di:flag_cma=1
[    8.462521] DI: CMA size 0x2800000.
[    8.466180] pre_irq:62
[    8.468678] post_irq:63
[    8.471264] DI: di_probe allocate rdma channel 0.
[    8.476156] di_get_vpu_clkb: get clk vpu error.
[    8.480808] DI: vpu clkb <334000000, 667000000>
[    8.485534] get clkb rate:333333328
[    8.489131] DI:enable vpu clkb.
[    8.492433] 0x000000e1:Y=e1,U=0,V=0
[    8.496051] 0x000000e2:Y=e2,U=0,V=0
[    8.499702] 0x000000e3:Y=e3,U=0,V=0
[    8.503345] 0x000000f0:Y=f0,U=0,V=0
[    8.506981] 0x000000f1:Y=f1,U=0,V=0
[    8.510619] 0x000000f2:Y=f2,U=0,V=0
[    8.514259] 0x000000f3:Y=f3,U=0,V=0
[    8.517899] 0x000000f4:Y=f4,U=0,V=0
[    8.521538] 0x000000f5:Y=f5,U=0,V=0
[    8.525178] 0x000000f6:Y=f6,U=0,V=0
[    8.528820] 0x000000f7:Y=f7,U=0,V=0
[    8.532459] 0x000000f8:Y=f8,U=0,V=0
[    8.536090] 0x000000f9:Y=f9,U=0,V=0
[    8.539738] 0x000000fa:Y=fa,U=0,V=0
[    8.543377] 0x000000fb:Y=fb,U=0,V=0
[    8.547018] 0x000000fc:Y=fc,U=0,V=0
[    8.550660] 0x000000fd:Y=fd,U=0,V=0
[    8.554298] 0x000000fe:Y=fe,U=0,V=0
[    8.557938] 0x000000ff:Y=ff,U=0,V=0
[    8.561578] 0x0000003a:Y=3a,U=0,V=0
[    8.565218] 0x0000003b:Y=3b,U=0,V=0
[    8.568858] 0x0000003c:Y=3c,U=0,V=0
[    8.572499] 0x0000003d:Y=3d,U=0,V=0
[    8.576138] 0x0000003e:Y=3e,U=0,V=0
[    8.579770] 0x0000003f:Y=3f,U=0,V=0
[    8.583418] DI: support multi decoding 61~62~63.
[    8.588309] DI: di_probe:Di use HRTIMER
[    8.592568] DI: di_probe:ok
[    8.595178] dim:dim_module_init
[    8.598667] dim:dim_module_init finish
[    8.602316] dil:dil_init.
[    8.605258] dil:dil_init ok.
[    8.608147] vdin_drv_init: major 509
[    8.612030] vdin_drv_init: vdin driver init done
[    8.616618] [viuin..]viuin_init_module viuin module init
[    8.622311] [viuin..]viuin_probe probe ok.
[    8.626712] [RX]-hdmirx: hdmirx_init.
[    8.630150] ESM HLD: Initializing...
[    8.634463] amlvid:info: amlvideo_init called
[    8.638203] amlvid:info: amlvideo_create_instance called
[    8.643671] amlvid:info: v4l2_dev.name=:amlvideo-000
[    8.648899] amlvideo-000: V4L2 device registered as video10
[    8.654491] amlvid:info: amlvideo_create_instance called
[    8.659955] amlvid:info: v4l2_dev.name=:amlvideo-001
[    8.665163] amlvideo-001: V4L2 device registered as video23
[    8.670952] PPMGRDRV: warn: ppmgr module init func called
[    8.676450] PPMGRDRV: info: ppmgr_driver_probe called
[    8.681625] Reserved memory: failed to init DMA memory pool at 0x00000000ed800000, size 0 MiB
[    8.690210] PPMGRDRV: info: ppmgr_dev major:507
[    8.695458] ionvideo-000: V4L2 device registered as video13
[    8.700724] ionvideo-001: V4L2 device registered as video14
[    8.706417] ionvideo-002: V4L2 device registered as video15
[    8.712140] ionvideo-003: V4L2 device registered as video16
[    8.717856] ionvideo-004: V4L2 device registered as video17
[    8.723573] ionvideo-005: V4L2 device registered as video18
[    8.729299] ionvideo-006: V4L2 device registered as video19
[    8.735010] ionvideo-007: V4L2 device registered as video20
[    8.740738] ionvideo-008: V4L2 device registered as video21
[    8.746357] ionvid: info: Video Technology Magazine Ion Video
[    8.752261] ionvid: info: Capture Board ver 1.0 successfully loaded
[    8.759049] videosync_create_instance dev_s ffffffc070761400,dev_s->dev ffffffc0ca1c2c00
[    8.766907] videosync_create_instance reg videosync.0
[    8.772178] aml_vecm_init:module init
[    8.772183] videosync_thread started
[    8.779853]
                VECM probe start
[    8.784614] Can't find  detect_colorbar.
[    8.788486] Can't find  detect_face.
[    8.792206] Can't find  detect_corn.
[    8.795917] Can't find  wb_sel.
[    8.799227] hdr:Can't find  cfg_en_osd_100.
[    8.803561] amlogic, vecm
[    8.806154] vlock dt support: 1
[    8.809459] vlock dt new_fsm: 0
[    8.812740] vlock dt hwver: 0
[    8.815850] vlock dt phlock_en: 0
[    8.819338] Can't find  vlock_en.
[    8.822793] Can't find  vlock_mode.
[    8.826439] Can't find  vlock_pll_m_limit.
[    8.830686] Can't find  vlock_line_limit.
[    8.834840] param_config vlock_en:1 md=0x4
[    8.839094] vlock: maxLine 524,maxPixel 1715
[    8.843506] vlock_status_init vlock_en:1
[    8.847582] aml_vecm_probe: ok
[    8.850858] amdolby_vision_init:module init
[    8.855356]
                amdolby_vision probe start & ver: 20181220
[    8.862156]
                cpu_id=2 tvmode=0
[    8.867134] dolby_vision_init_receiver(dvel)
[    8.871435] dolby_vision_init_receiver: dvel
[    8.875947] amdolby_vision_probe: ok
[    8.879575] dovi disable in uboot
[    8.883725] meson-mmc: mmc driver version: 3.02, 2017-05-15: New Emmc Host Controller
[    8.891722] meson-mmc: >>>>>>>>hostbase ffffff80086aa000, dmode
[    8.897409] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[    8.902898] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[    8.948143] meson-mmc: meson_mmc_probe() : success!
[    8.953894] meson-mmc: >>>>>>>>hostbase ffffff80086c5000, dmode
[    8.957231] meson-mmc: emmc: resp_timeout,vstat:0x9dbf0800,virqc:3fff
[    8.957234] meson-mmc: emmc: err: wait for desc write back, bus_fsm:0x7
[    8.957248] meson-mmc: meson_mmc_irq_thread_v3() 653: set 1st retry!
[    8.957249] meson-mmc: retry cmd 1 the 3-th time(s)
[    8.958245] meson-mmc: emmc: resp_timeout,vstat:0x9dbf0800,virqc:3fff
[    8.958247] meson-mmc: emmc: err: wait for desc write back, bus_fsm:0x7
[    8.958256] meson-mmc: retry cmd 1 the 2-th time(s)
[    8.959250] meson-mmc: emmc: resp_timeout,vstat:0x9dbf0800,virqc:3fff
[    8.959252] meson-mmc: emmc: err: wait for desc write back, bus_fsm:0x7
[    8.959261] meson-mmc: retry cmd 1 the 1-th time(s)
[    8.960260] meson-mmc: emmc: resp_timeout,vstat:0xa1bf2800,virqc:3fff
[    8.960262] meson-mmc: emmc: err: wait for irq service, bus_fsm:0x8
[    8.960272] meson-mmc: Command retried failed line:675, cmd:1
[    9.038275] meson-mmc: gpio_cd = 1ca
[    9.080147] meson-mmc: meson_mmc_probe() : success!
[    9.081904] cectx ff80023c.aocec: cec driver date:2019/10/22: finetune ARB rising time
[    9.090920] cectx ff80023c.aocec: compatible:amlogic, aocec-sm1
[    9.096359] cectx ff80023c.aocec: cecb_ver:0x2
[    9.100948] cectx ff80023c.aocec: line_reg:0x1
[    9.105536] cectx ff80023c.aocec: line_bit:0x3
[    9.110132] cectx ff80023c.aocec: ee_to_ao:0x1
[    9.114828] input: cec_input as /devices/virtual/input/input0
[    9.121173] cectx ff80023c.aocec: not find 'port_num'
[    9.125823] cectx ff80023c.aocec: using cec:1
[    9.130353] cectx ff80023c.aocec: no hdmirx regs
[    9.135091] cectx ff80023c.aocec: no hhi regs
[    9.140855] irq cnt:2, a:46, b45
[    9.143631] cectx ff80023c.aocec: wakeup_reason:0x0
[    9.148063] cectx ff80023c.aocec: cev val1: 0x0;val2: 0x0
[    9.153559] cectx ff80023c.aocec: aml_cec_probe success end
[    9.159529] unifykey: storage in base: 0xffffffc005000000
[    9.164824] unifykey: storage out base: 0xffffffc005040000
[    9.170448] unifykey: storage block base: 0xffffffc005080000
[    9.176259] unifykey: probe done!
[    9.180021] unifykey: no efuse-version set, use default value: -1
[    9.185998] unifykey: key unify config unifykey-num is 14
[    9.191551] unifykey: key unify fact unifykey-num is 17
[    9.196888] unifykey: unifykey_devno: 1f600000
[    9.202061] unifykey: device unifykeys created ok
[    9.206388] unifykey: aml_unifykeys_init done!
[    9.211087] meson ts init
[    9.213749] tsensor id: 0
[    9.216600] r1p1_tsensor_read  valid cnt is 0
[    9.220994] tsensor trim info: 0xfa00005a!
[    9.225229] tsensor hireboot: 0xc0ff2a40
[    9.229356] meson ts init
[    9.232075] tsensor id: 1
[    9.234929] r1p1_tsensor_read  valid cnt is 0
[    9.239357] tsensor trim info: 0xfa00004c!
[    9.243597] tsensor hireboot: 0xc0ff2a40
[    9.247750] audio_dsp: [dsp]register dsp to char divece(257)
[    9.253634] amaudio: amaudio: driver amaudio init!
[    9.258724] amaudio: amaudio_init - amaudio: driver amaudio succuess!
[    9.265550] amlkaraoke init success!
[    9.268889] sysled: module init
[    9.272246] meson_wdt ffd0f0d0.watchdog: start watchdog
[    9.277400] meson_wdt ffd0f0d0.watchdog: creat work queue for watch dog
[    9.284226] meson-mmc: card IN
[    9.288438] meson_wdt ffd0f0d0.watchdog: AML Watchdog Timer probed done
[    9.294616] amlogic rfkill init
[    9.297840] meson-saradc ff809000.saradc: set delay per tick to <1ms> by default.
[    9.305061] meson-saradc ff809000.saradc: set ticks per period to <1> by default.
[    9.313516] dmc_monitor_probe
[    9.316577] atv_demod: aml_atvdemod_init: OK, atv demod version: V2.15.
[    9.322698] defendkey ff630218.defendkey: Reserved memory is not enough!
[    9.329412] defendkey: probe of ff630218.defendkey failed with error -22
[    9.338845] Error: Driver 'spdif-dit' is already registered, aborting...
[    9.343432] asoc debug: aml_audio_controller_probe-130
[    9.349100] aml_spdif_platform_probe, spdif ID = 0
[    9.349437] SPDIF id 0 asrc_id:0 auto_asrc:0
[    9.349525] spdifout_play_with_zerodata, spdif id:0 enable:0
[    9.349530] spdif_a fifo ctrl, frddr:0 type:3, 32 bits, chmask 0x3, swap 0x10
[    9.349535] spdif_info: rate: 48000, channel status ch0_l:0x100, ch0_r:0x100, ch1_l:0x200, ch1_r:0x200
[    9.349541] hdmitx: audio: aout notify format CT_PCM
[    9.353502] spdif_a is set to enable
[    9.353517] aml_spdif_platform_probe, register soc platform
[    9.359764] audio-ddr-manager ff660000.audiobus:ddr_manager: 0, irqs toddr 31, frddr 35
[    9.367383] audio-ddr-manager ff660000.audiobus:ddr_manager: 1, irqs toddr 32, frddr 36
[    9.375530] audio-ddr-manager ff660000.audiobus:ddr_manager: 2, irqs toddr 33, frddr 37
[    9.383677] audio-ddr-manager ff660000.audiobus:ddr_manager: 3, irqs toddr 34, frddr 38
[    9.388183] meson-mmc: normal card in
[    9.396152] audiolocker_platform_probe
[    9.400744] Register vad
[    9.402593] aml_dai_spdif_probe
[    9.405519] set normal 512 fs /4 fs
[    9.405573]   set spdifout clk:6144000, mpll:24576000
[    9.405576]   get spdifout clk:6143997, mpll:24575987
[    9.405582] aml_dai_set_spdif_fmt , fmt 0x4010
[    9.405650] aml_spdif_new spdif_a, clk continuous:1
[    9.405652] spdifout_play_with_zerodata_free, spdif id:0
[    9.405863] asoc-aml-card odroid_hdmi: dit-hifi <-> SPDIF mapping ok
[    9.412448] snd_card_add_kcontrols card:ffffffc07078a818
[    9.417465] effect_v2 is not init
[    9.420927] Not init vad
[    9.420928] Failed to add VAD controls
[    9.424829] eq/drc v1 function enable
[    9.428637] no node audio_effect for eq/drc info!
[    9.433487] Failed to add audio effects v1 controls
[    9.438643] Netfilter messages via NETLINK v0.30.
[    9.443453] Initializing XFRM netlink socket
[    9.447795] NET: Registered protocol family 17
[    9.452420] Key type dns_resolver registered
[    9.457512] Registered swp emulation handler
[    9.461236] Registered cp15_barrier emulation handler
[    9.466420] Registered setend emulation handler
[    9.471131] disable EAS feature
[    9.475703] registered taskstats version 1
[    9.478830] AppArmor: AppArmor sha1 policy hashing enabled
[    9.489238] dwc3 ff500000.dwc3: Configuration mismatch. dr_mode forced to host
[    9.494284] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    9.497298] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    9.505351] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe64 hci version 0x110 quirks 0x00010010
[    9.512238] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[    9.512239] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[    9.526696] xhci-hcd xhci-hcd.0.auto: irq 22, io mem 0xff500000
[    9.532834] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    9.539684] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.547045] usb usb1: Product: xHCI Host Controller
[    9.552071] usb usb1: Manufacturer: Linux 4.9.236-arm64 xhci-hcd
[    9.558219] usb usb1: SerialNumber: xhci-hcd.0.auto
[    9.563672] hub 1-0:1.0: USB hub found
[    9.567172] hub 1-0:1.0: 2 ports detected
[    9.571541] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    9.576931] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    9.584776] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    9.593041] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    9.599888] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.607257] usb usb2: Product: xHCI Host Controller
[    9.608165] meson-mmc: actual_clock :400000, HHI_nand: 0x80
[    9.608167] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x1000033c
[    9.622035] meson-aml-mmc ffe05000.sd: divider requested rate 200000000 != actual rate 199999997: ret=0
[    9.622037] meson-mmc: actual_clock :199999997, HHI_nand: 0x80
[    9.622038] meson-mmc: [meson_mmc_clk_set_rate_v3] after clock: 0x10000245
[    9.622041] meson-mmc: Data 1 aligned delay is 0
[    9.622044] meson-mmc: sd: clk 199999997 tuning start
[    9.635731] meson-mmc: sd: adj_win: < 0 1 2 3 >
[    9.635735] meson-mmc: step:4, delay1:0x4104104, delay2:0x4004104
[    9.649672] meson-mmc: sd: adj_win: < 0 1 2 3 >
[    9.649675] meson-mmc: step:8, delay1:0x8208208, delay2:0x8008208
[    9.664040] meson-mmc: sd: adj_win: < 0 1 2 3 >
[    9.664042] meson-mmc: step:12, delay1:0xc30c30c, delay2:0xc00c30c
[    9.678422] meson-mmc: sd: adj_win: < 0 1 2 3 >
[    9.678425] meson-mmc: step:16, delay1:0x10410410, delay2:0x10010410
[    9.692297] meson-mmc: sd: adj_win: < 0 1 2 3 >
[    9.692300] meson-mmc: step:20, delay1:0x14514514, delay2:0x14014514
[    9.706157] meson-mmc: sd: adj_win: < 1 2 3 4 >
[    9.706160] meson-mmc: left:3, right:0, mid:4, size:4
[    9.706163] meson-mmc: step:0, delay1:0x0, delay2:0x0
[    9.706165] meson-mmc: sd: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x22000
[    9.706166] meson-mmc: delay1:0x0, delay2:0x0
[    9.706174] sd: new ultra high speed SDR104 SDHC card at address 59b4
[    9.706539] sd: clock 199999997, 4-bit-bus-width
[    9.706539] mmcblk1: sd:59b4 00000 29.8 GiB
[    9.707356]  mmcblk1: p1 p2
[    9.760999] usb usb2: Manufacturer: Linux 4.9.236-arm64 xhci-hcd
[    9.767148] usb usb2: SerialNumber: xhci-hcd.0.auto
[    9.772567] hub 2-0:1.0: USB hub found
[    9.776090] hub 2-0:1.0: 1 port detected
[    9.780590] hctosys: unable to open rtc device (rtc0)
[    9.785616] dwc_otg ff400000.dwc2_a: dwc_otg_driver_probe(ffffffc0ca150800)
[    9.785658] dwc_otg: usb0: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: ffe09000, ctrl: 0
[    9.794021] dwc_otg_driver_probe host only, not probe usb_otg!!!
[    9.800820] meson_cdev probe
[    9.803199] thermal: read gpupp failed
[    9.807236] meson_cdev index: 0
[    9.810511] thermal: read gpupp failed
[    9.814377] meson_cdev index: 1
[    9.817592] cpucore_cooling_register, max_cpu_core_num:4
[    9.823207] meson_cdev index: 2
[    9.826347] thermal: read gpupp failed
[    9.830275] meson_cdev index: 3
[    9.833581] find tzd id: 0
[    9.836544] find tzd id: 0
[    9.839316] meson_cdev probe done
[    9.842874] gxbb_pm: enter meson_pm_probe!
[    9.846982] no vddio3v3_en pin
[    9.850011] pm-meson aml_pm: Can't get switch_clk81
[    9.855060] gxbb_pm: meson_pm_probe done
[    9.859432] ALSA device list:
[    9.862234]   #0: ODROID-HDMI
[    9.865450] meson_uart ff803000.serial: ttyS0 use xtal(24M) 24000000 change 115200 to 115200
[    9.869751] Freeing unused kernel memory: 4928K
[   10.107897] libata: disagrees about version of symbol module_layout
[   10.131763] spi_meson_spicc: disagrees about version of symbol module_layout
[   10.441138] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[   10.746363] systemd[1]: System time before build time, advancing clock.
[   10.800198] ipv6: disagrees about version of symbol module_layout
[   10.808066] x_tables: disagrees about version of symbol module_layout
[   10.813479] cgroup: cgroup2: unknown option "nsdelegate"
[   10.825365] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   10.841912] systemd[1]: Detected architecture arm64.
[   10.865003] systemd[1]: Set hostname to <DietPi>.
[   11.018218] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[   11.029839] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[   11.164389] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.184259] systemd[1]: Reached target Remote File Systems.
[   11.204528] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.224514] systemd[1]: Listening on udev Control Socket.
[   11.228150] vout: aml_tvout_mode_work: monitor_timeout
[   11.248390] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.391269] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[   12.215812] systemd-journald[1992]: Received request to flush runtime journal from PID 1
[   12.363368] libata: disagrees about version of symbol module_layout
[   12.372345] media_clock: disagrees about version of symbol module_layout
[   12.418548] i2c_meson_master: disagrees about version of symbol module_layout
[   12.419093] i2c_meson_master: disagrees about version of symbol module_layout
[   12.420322] spi_meson_spicc: disagrees about version of symbol module_layout
[   12.462422] ionvid: dbg: ionvideo open
[   12.472895] ionvid: dbg: vidioc_close!!!!
[   12.472909] ionvid: dbg: vidioc_close
[   12.473023] ionvid: dbg: ionvideo open
[   12.474501] ionvid: dbg: vidioc_close!!!!
[   12.474517] ionvid: dbg: vidioc_close
[   12.477582] ionvid: dbg: ionvideo open
[   12.477772] ionvid: dbg: vidioc_close!!!!
[   12.477786] ionvid: dbg: vidioc_close
[   12.477819] ionvid: dbg: ionvideo open
[   12.478134] ionvid: dbg: vidioc_close!!!!
[   12.478149] ionvid: dbg: vidioc_close
[   12.478194] ionvid: dbg: ionvideo open
[   12.478366] ionvid: dbg: vidioc_close!!!!
[   12.478378] ionvid: dbg: vidioc_close
[   12.481475] ionvid: dbg: ionvideo open
[   12.481648] ionvid: dbg: vidioc_close!!!!
[   12.481659] ionvid: dbg: vidioc_close
[   12.489646] ionvid: dbg: ionvideo open
[   12.489819] ionvid: dbg: vidioc_close!!!!
[   12.489827] ionvid: dbg: vidioc_close
[   12.495335] ionvid: dbg: ionvideo open
[   12.495492] ionvid: dbg: vidioc_close!!!!
[   12.495502] ionvid: dbg: vidioc_close
[   12.496036] ionvid: dbg: ionvideo open
[   12.496940] ionvid: dbg: vidioc_close!!!!
[   12.496955] ionvid: dbg: vidioc_close
[   13.608541] meson6-dwmac ff3f0000.ethernet eth0: fail to init PTP.
[   16.669008] meson6-dwmac ff3f0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   22.768183] ipv6: disagrees about version of symbol module_layout
[   22.774745] ipv6: disagrees about version of symbol module_layout
[   23.210951] ipv6: disagrees about version of symbol module_layout
[   53.749614] ipv6: disagrees about version of symbol module_layout
[   68.604501] fb: mem_free_work, free memory: addr:800000
fdisk -l returns info on the microsd, nothing else. lspci -t returns "-[0000:00]---00.0-[01-ff]----00.0".
Many thanks, latest kernel provided by Hardkernel will be built, I'll inform you, once it's ready, let's see if that helps. I also forwarded the relevant part of your logs. I'm not good in reading those, but amlogic-pcie-v2 fc000000.pcieA: the device class is not reported correctly from the register looks like it could be related. Btw, if you want to follow: https://forum.odroid.com/viewtopic.php?p=317264#p317264
Okay, new kernel build is up:
apt update
apt install linux-image-arm64-odroid-c4
BitWise
Post by BitWise »
Apt install command results in error.
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.9.241-arm64_4.9.241-20210104-C4_arm64.deb (--unpack):
 trying to overwrite '/boot/meson64_odroidc4.dtb', which is also in package linux-image-4.9.236-arm64 4.9.236-20201220-C4
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Clean install fails on first boot setup with error "E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).". apt --fix-broken install results in same error as above.
tobetter
Post by tobetter »
@BitWise, by any chance, are you able to boot to the Petitboot and run fdisk or lspci to check your SATA issue?
BitWise
Post by BitWise »
Fdisk -l finds the sata drive, lspci returns:
00:00.0 Class 0604: 16c3:abcd
01:00.0 Class 0101: 1b21:0611
Strange that in my case, the file was explicitly replaced nicely: https://github.com/MichaIng/DietPi/issu ... -754921553
But as can be seen, I found another issue that the postinst script does not rename the new kernel on HC4. Please try:
mv /boot/Image.gz /boot/Image.gz.bak
mv /boot/Image /boot/Image.gz
However, the SATA drive is already detected now, so you're able to mount it already? I still recommend to do the above naming steps.
