JuniorChange
Posts: 8 Joined: Wed May 06, 2020 5:14 am
Post
by JuniorChange » Wed Dec 23, 2020 12:23 am
Greetings and Happy Holidays!
I am also having this exact same problem I tried the fix:
sudo -u radarr /opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr
But I am unable to execute /opt/radarr/Radarr
root@DietPi:~# sudo -u radarr /opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr
sudo: unable to execute /opt/radarr/Radarr: No such file or directory
I tried uninstalling, rebooting, and find / -name "radarr"
But sadly still run into the same error that Mike originally had
root@DietPi:~# systemctl status radarr.service
● radarr.service - Radarr Daemon (DietPi)
Loaded: loaded (/etc/systemd/system/radarr.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2020-12-22 18:16:38 EST; 6min ago
Process: 830 ExecStart=/opt/radarr/Radarr -nobrowser -data=/mnt/dietpi_userdata/radarr (code=exited, status
=203/EXEC)
Main PID: 830 (code=exited, status=203/EXEC)
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Main process exited, code=exited, status=2
03/EXEC
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Failed with result 'exit-code'.
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Service RestartSec=100ms expired, scheduling restart.
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Scheduled restart job, restart counter is at 5.
Dec 22 18:16:38 DietPi systemd[1]: Stopped Radarr Daemon (DietPi).
Dec 22 18:16:38 DietPi systemd[1]: radarr.service: Start request repeated too quickly.
Dec 22 18:16:38 DietPi systemd[1]: Failed to start Radarr Daemon (DietPi).
Any help would be appreciated, Happy Holidays!
Posts: 4203 Joined: Sat Nov 16, 2019 12:49 am
Post
by Joulinar » Wed Dec 23, 2020 12:26 am
not sure if this is the same issue as you are missing the executable
Can you check if it's available
JuniorChange
Post
by JuniorChange » Wed Dec 23, 2020 12:38 am
I wasn't sure how much of the output you needed so I copied it all my bad if its long
root@DietPi:~# ls -la /opt/radarr/
total 123080
drwxr-xr-x 6 radarr dietpi 24576 Dec 10 22:59 .
drwxr-xr-x 6 root root 4096 Dec 22 18:14 ..
-rw-r--r-- 1 radarr dietpi 116992 Dec 10 22:59 createdump
-rw-r--r-- 1 radarr dietpi 190464 Dec 10 22:59 Dapper.dll
drwxr-xr-x 2 radarr dietpi 4096 Dec 10 22:59 de-DE
-rw-r--r-- 1 radarr dietpi 91648 Dec 10 22:59 FluentMigrator.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 54272 Dec 10 22:59 FluentMigrator.dll
-rw-r--r-- 1 radarr dietpi 114176 Dec 10 22:59 FluentMigrator.Runner.Core.dll
-rw-r--r-- 1 radarr dietpi 67072 Dec 10 22:59 FluentMigrator.Runner.dll
-rw-r--r-- 1 radarr dietpi 21504 Dec 10 22:59 FluentMigrator.Runner.SQLite.dll
-rw-r--r-- 1 radarr dietpi 339456 Dec 10 22:59 FluentValidation.dll
-rw-r--r-- 1 radarr dietpi 187392 Dec 10 22:59 Ical.Net.dll
-rw-r--r-- 1 radarr dietpi 198144 Dec 10 22:59 ICSharpCode.SharpZipLib.dll
-rw-r--r-- 1 radarr dietpi 20992 Dec 10 22:59 Interop.NetFwTypeLib.dll
-rw-r--r-- 1 radarr dietpi 80384 Dec 10 22:59 Kveer.XmlRPC.dll
-rw-r--r-- 1 radarr dietpi 2932264 Dec 10 22:59 libclrjit.so
-rw-r--r-- 1 radarr dietpi 9496592 Dec 10 22:59 libcoreclr.so
-rw-r--r-- 1 radarr dietpi 749400 Dec 10 22:59 libcoreclrtraceptprovider.so
-rw-r--r-- 1 radarr dietpi 974368 Dec 10 22:59 libdbgshim.so
-rw-r--r-- 1 radarr dietpi 397464 Dec 10 22:59 libhostfxr.so
-rw-r--r-- 1 radarr dietpi 331992 Dec 10 22:59 libhostpolicy.so
-rw-r--r-- 1 radarr dietpi 246736 Dec 10 22:59 libMonoPosixHelper.so
-rw-r--r-- 1 radarr dietpi 3620904 Dec 10 22:59 libmscordaccore.so
-rw-r--r-- 1 radarr dietpi 2883680 Dec 10 22:59 libmscordbi.so
-rw-r--r-- 1 radarr dietpi 35141 Dec 10 22:59 LICENSE
drwxr-xr-x 3 radarr dietpi 4096 Dec 10 22:59 Localization
-rw-r--r-- 1 radarr dietpi 115080 Dec 10 22:59 Microsoft.AspNetCore.Antiforgery.dll
-rw-r--r-- 1 radarr dietpi 53640 Dec 10 22:59 Microsoft.AspNetCore.Authentication.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 113032 Dec 10 22:59 Microsoft.AspNetCore.Authentication.Cookies.dll
-rw-r--r-- 1 radarr dietpi 84872 Dec 10 22:59 Microsoft.AspNetCore.Authentication.Core.dll
-rw-r--r-- 1 radarr dietpi 160136 Dec 10 22:59 Microsoft.AspNetCore.Authentication.dll
-rw-r--r-- 1 radarr dietpi 97672 Dec 10 22:59 Microsoft.AspNetCore.Authentication.OAuth.dll
-rw-r--r-- 1 radarr dietpi 88968 Dec 10 22:59 Microsoft.AspNetCore.Authorization.dll
-rw-r--r-- 1 radarr dietpi 53632 Dec 10 22:59 Microsoft.AspNetCore.Authorization.Policy.dll
-rw-r--r-- 1 radarr dietpi 48008 Dec 10 22:59 Microsoft.AspNetCore.Components.Authorization.dll
-rw-r--r-- 1 radarr dietpi 432520 Dec 10 22:59 Microsoft.AspNetCore.Components.dll
-rw-r--r-- 1 radarr dietpi 60808 Dec 10 22:59 Microsoft.AspNetCore.Components.Forms.dll
-rw-r--r-- 1 radarr dietpi 865160 Dec 10 22:59 Microsoft.AspNetCore.Components.Server.dll
-rw-r--r-- 1 radarr dietpi 122240 Dec 10 22:59 Microsoft.AspNetCore.Components.Web.dll
-rw-r--r-- 1 radarr dietpi 36224 Dec 10 22:59 Microsoft.AspNetCore.Connections.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 46464 Dec 10 22:59 Microsoft.AspNetCore.CookiePolicy.dll
-rw-r--r-- 1 radarr dietpi 87936 Dec 10 22:59 Microsoft.AspNetCore.Cors.dll
-rw-r--r-- 1 radarr dietpi 71048 Dec 10 22:59 Microsoft.AspNetCore.Cryptography.Internal.dll
-rw-r--r-- 1 radarr dietpi 36744 Dec 10 22:59 Microsoft.AspNetCore.Cryptography.KeyDerivation.dll
-rw-r--r-- 1 radarr dietpi 42888 Dec 10 22:59 Microsoft.AspNetCore.DataProtection.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 445320 Dec 10 22:59 Microsoft.AspNetCore.DataProtection.dll
-rw-r--r-- 1 radarr dietpi 36744 Dec 10 22:59 Microsoft.AspNetCore.DataProtection.Extensions.dll
-rw-r--r-- 1 radarr dietpi 21384 Dec 10 22:59 Microsoft.AspNetCore.Diagnostics.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 440712 Dec 10 22:59 Microsoft.AspNetCore.Diagnostics.dll
-rw-r--r-- 1 radarr dietpi 46976 Dec 10 22:59 Microsoft.AspNetCore.Diagnostics.HealthChecks.dll
-rw-r--r-- 1 radarr dietpi 37768 Dec 10 22:59 Microsoft.AspNetCore.dll
-rw-r--r-- 1 radarr dietpi 35208 Dec 10 22:59 Microsoft.AspNetCore.HostFiltering.dll
-rw-r--r-- 1 radarr dietpi 33672 Dec 10 22:59 Microsoft.AspNetCore.Hosting.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 416648 Dec 10 22:59 Microsoft.AspNetCore.Hosting.dll
-rw-r--r-- 1 radarr dietpi 18304 Dec 10 22:59 Microsoft.AspNetCore.Hosting.Server.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 33160 Dec 10 22:59 Microsoft.AspNetCore.Html.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 238984 Dec 10 22:59 Microsoft.AspNetCore.Http.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 49536 Dec 10 22:59 Microsoft.AspNetCore.Http.Connections.Common.dll
-rw-r--r-- 1 radarr dietpi 313736 Dec 10 22:59 Microsoft.AspNetCore.Http.Connections.dll
-rw-r--r-- 1 radarr dietpi 247176 Dec 10 22:59 Microsoft.AspNetCore.Http.dll
-rw-r--r-- 1 radarr dietpi 94600 Dec 10 22:59 Microsoft.AspNetCore.Http.Extensions.dll
-rw-r--r-- 1 radarr dietpi 30600 Dec 10 22:59 Microsoft.AspNetCore.Http.Features.dll
-rw-r--r-- 1 radarr dietpi 67464 Dec 10 22:59 Microsoft.AspNetCore.HttpOverrides.dll
-rw-r--r-- 1 radarr dietpi 41352 Dec 10 22:59 Microsoft.AspNetCore.HttpsPolicy.dll
-rw-r--r-- 1 radarr dietpi 219520 Dec 10 22:59 Microsoft.AspNetCore.Identity.dll
-rw-r--r-- 1 radarr dietpi 59264 Dec 10 22:59 Microsoft.AspNetCore.Localization.dll
-rw-r--r-- 1 radarr dietpi 19848 Dec 10 22:59 Microsoft.AspNetCore.Localization.Routing.dll
-rw-r--r-- 1 radarr dietpi 15752 Dec 10 22:59 Microsoft.AspNetCore.Metadata.dll
-rw-r--r-- 1 radarr dietpi 219008 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 82312 Dec 10 22:59 Microsoft.AspNetCore.Mvc.ApiExplorer.dll
-rw-r--r-- 1 radarr dietpi 2149760 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Core.dll
-rw-r--r-- 1 radarr dietpi 48008 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Cors.dll
-rw-r--r-- 1 radarr dietpi 119688 Dec 10 22:59 Microsoft.AspNetCore.Mvc.DataAnnotations.dll
-rw-r--r-- 1 radarr dietpi 28552 Dec 10 22:59 Microsoft.AspNetCore.Mvc.dll
-rw-r--r-- 1 radarr dietpi 15752 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Formatters.Json.dll
-rw-r--r-- 1 radarr dietpi 125824 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Formatters.Xml.dll
-rw-r--r-- 1 radarr dietpi 45448 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Localization.dll
-rw-r--r-- 1 radarr dietpi 269704 Dec 10 22:59 Microsoft.AspNetCore.Mvc.Razor.dll
-rw-r--r-- 1 radarr dietpi 510344 Dec 10 22:59 Microsoft.AspNetCore.Mvc.RazorPages.dll
-rw-r--r-- 1 radarr dietpi 326024 Dec 10 22:59 Microsoft.AspNetCore.Mvc.TagHelpers.dll
-rw-r--r-- 1 radarr dietpi 918920 Dec 10 22:59 Microsoft.AspNetCore.Mvc.ViewFeatures.dll
-rw-r--r-- 1 radarr dietpi 80256 Dec 10 22:59 Microsoft.AspNetCore.Owin.dll
-rw-r--r-- 1 radarr dietpi 72072 Dec 10 22:59 Microsoft.AspNetCore.Razor.dll
-rw-r--r-- 1 radarr dietpi 68488 Dec 10 22:59 Microsoft.AspNetCore.Razor.Runtime.dll
-rw-r--r-- 1 radarr dietpi 15752 Dec 10 22:59 Microsoft.AspNetCore.ResponseCaching.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 144264 Dec 10 22:59 Microsoft.AspNetCore.ResponseCaching.dll
-rw-r--r-- 1 radarr dietpi 76680 Dec 10 22:59 Microsoft.AspNetCore.ResponseCompression.dll
-rw-r--r-- 1 radarr dietpi 241544 Dec 10 22:59 Microsoft.AspNetCore.Rewrite.dll
-rw-r--r-- 1 radarr dietpi 57224 Dec 10 22:59 Microsoft.AspNetCore.Routing.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 763784 Dec 10 22:59 Microsoft.AspNetCore.Routing.dll
-rw-r--r-- 1 radarr dietpi 579464 Dec 10 22:59 Microsoft.AspNetCore.Server.HttpSys.dll
-rw-r--r-- 1 radarr dietpi 662920 Dec 10 22:59 Microsoft.AspNetCore.Server.IIS.dll
-rw-r--r-- 1 radarr dietpi 48008 Dec 10 22:59 Microsoft.AspNetCore.Server.IISIntegration.dll
-rw-r--r-- 1 radarr dietpi 1599880 Dec 10 22:59 Microsoft.AspNetCore.Server.Kestrel.Core.dll
-rw-r--r-- 1 radarr dietpi 21888 Dec 10 22:59 Microsoft.AspNetCore.Server.Kestrel.dll
-rw-r--r-- 1 radarr dietpi 151432 Dec 10 22:59 Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.dll
-rw-r--r-- 1 radarr dietpi 87432 Dec 10 22:59 Microsoft.AspNetCore.Session.dll
-rw-r--r-- 1 radarr dietpi 37256 Dec 10 22:59 Microsoft.AspNetCore.SignalR.Common.dll
-rw-r--r-- 1 radarr dietpi 425352 Dec 10 22:59 Microsoft.AspNetCore.SignalR.Core.dll
-rw-r--r-- 1 radarr dietpi 33160 Dec 10 22:59 Microsoft.AspNetCore.SignalR.dll
-rw-r--r-- 1 radarr dietpi 77192 Dec 10 22:59 Microsoft.AspNetCore.SignalR.Protocols.Json.dll
-rw-r--r-- 1 radarr dietpi 35208 Dec 10 22:59 Microsoft.AspNetCore.SignalR.Protocols.NewtonsoftJson.dll
-rw-r--r-- 1 radarr dietpi 162176 Dec 10 22:59 Microsoft.AspNetCore.StaticFiles.dll
-rw-r--r-- 1 radarr dietpi 40840 Dec 10 22:59 Microsoft.AspNetCore.WebSockets.dll
-rw-r--r-- 1 radarr dietpi 234368 Dec 10 22:59 Microsoft.AspNetCore.WebUtilities.dll
-rw-r--r-- 1 radarr dietpi 990080 Dec 10 22:59 Microsoft.CSharp.dll
-rw-r--r-- 1 radarr dietpi 22632 Dec 10 22:59 Microsoft.DotNet.PlatformAbstractions.dll
-rw-r--r-- 1 radarr dietpi 49032 Dec 10 22:59 Microsoft.Extensions.Caching.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 64392 Dec 10 22:59 Microsoft.Extensions.Caching.Memory.dll
-rw-r--r-- 1 radarr dietpi 21384 Dec 10 22:59 Microsoft.Extensions.Configuration.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 25480 Dec 10 22:59 Microsoft.Extensions.Configuration.Binder.dll
-rw-r--r-- 1 radarr dietpi 19848 Dec 10 22:59 Microsoft.Extensions.Configuration.CommandLine.dll
-rw-r--r-- 1 radarr dietpi 27528 Dec 10 22:59 Microsoft.Extensions.Configuration.dll
-rw-r--r-- 1 radarr dietpi 20872 Dec 10 22:59 Microsoft.Extensions.Configuration.EnvironmentVariables.dll
-rw-r--r-- 1 radarr dietpi 22920 Dec 10 22:59 Microsoft.Extensions.Configuration.FileExtensions.dll
-rw-r--r-- 1 radarr dietpi 30592 Dec 10 22:59 Microsoft.Extensions.Configuration.Ini.dll
-rw-r--r-- 1 radarr dietpi 21896 Dec 10 22:59 Microsoft.Extensions.Configuration.Json.dll
-rw-r--r-- 1 radarr dietpi 27528 Dec 10 22:59 Microsoft.Extensions.Configuration.KeyPerFile.dll
-rw-r--r-- 1 radarr dietpi 20872 Dec 10 22:59 Microsoft.Extensions.Configuration.UserSecrets.dll
-rw-r--r-- 1 radarr dietpi 42376 Dec 10 22:59 Microsoft.Extensions.Configuration.Xml.dll
-rw-r--r-- 1 radarr dietpi 37768 Dec 10 22:59 Microsoft.Extensions.DependencyInjection.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 72584 Dec 10 22:59 Microsoft.Extensions.DependencyInjection.dll
-rw-r--r-- 1 radarr dietpi 58472 Dec 10 22:59 Microsoft.Extensions.DependencyModel.dll
-rw-r--r-- 1 radarr dietpi 31624 Dec 10 22:59 Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 100232 Dec 10 22:59 Microsoft.Extensions.Diagnostics.HealthChecks.dll
-rw-r--r-- 1 radarr dietpi 17800 Dec 10 22:59 Microsoft.Extensions.FileProviders.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 23424 Dec 10 22:59 Microsoft.Extensions.FileProviders.Composite.dll
-rw-r--r-- 1 radarr dietpi 69000 Dec 10 22:59 Microsoft.Extensions.FileProviders.Embedded.dll
-rw-r--r-- 1 radarr dietpi 35712 Dec 10 22:59 Microsoft.Extensions.FileProviders.Physical.dll
-rw-r--r-- 1 radarr dietpi 39304 Dec 10 22:59 Microsoft.Extensions.FileSystemGlobbing.dll
-rw-r--r-- 1 radarr dietpi 25984 Dec 10 22:59 Microsoft.Extensions.Hosting.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 41352 Dec 10 22:59 Microsoft.Extensions.Hosting.dll
-rw-r--r-- 1 radarr dietpi 21384 Dec 10 22:59 Microsoft.Extensions.Hosting.WindowsServices.dll
-rw-r--r-- 1 radarr dietpi 142728 Dec 10 22:59 Microsoft.Extensions.Http.dll
-rw-r--r-- 1 radarr dietpi 524160 Dec 10 22:59 Microsoft.Extensions.Identity.Core.dll
-rw-r--r-- 1 radarr dietpi 85376 Dec 10 22:59 Microsoft.Extensions.Identity.Stores.dll
-rw-r--r-- 1 radarr dietpi 21896 Dec 10 22:59 Microsoft.Extensions.Localization.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 58248 Dec 10 22:59 Microsoft.Extensions.Localization.dll
-rw-r--r-- 1 radarr dietpi 48520 Dec 10 22:59 Microsoft.Extensions.Logging.Abstractions.dll
-rw-r--r-- 1 radarr dietpi 20360 Dec 10 22:59 Microsoft.Extensions.Logging.Configuration.dll
-rw-r--r-- 1 radarr dietpi 28040 Dec 10 22:59 Microsoft.Extensions.Logging.Console.dll
-rw-r--r-- 1 radarr dietpi 17800 Dec 10 22:59 Microsoft.Extensions.Logging.Debug.dll
-rw-r--r-- 1 radarr dietpi 34184 Dec 10 22:59 Microsoft.Extensions.Logging.dll
-rw-r--r-- 1 radarr dietpi 21896 Dec 10 22:59 Microsoft.Extensions.Logging.EventLog.dll
-rw-r--r-- 1 radarr dietpi 29568 Dec 10 22:59 Microsoft.Extensions.Logging.EventSource.dll
-rw-r--r-- 1 radarr dietpi 29576 Dec 10 22:59 Microsoft.Extensions.Logging.TraceSource.dll
-rw-r--r-- 1 radarr dietpi 32136 Dec 10 22:59 Microsoft.Extensions.ObjectPool.dll
-rw-r--r-- 1 radarr dietpi 18312 Dec 10 22:59 Microsoft.Extensions.Options.ConfigurationExtensions.dll
-rw-r--r-- 1 radarr dietpi 20872 Dec 10 22:59 Microsoft.Extensions.Options.DataAnnotations.dll
-rw-r--r-- 1 radarr dietpi 50568 Dec 10 22:59 Microsoft.Extensions.Options.dll
-rw-r--r-- 1 radarr dietpi 16376 Dec 10 22:59 Microsoft.Extensions.PlatformAbstractions.dll
-rw-r--r-- 1 radarr dietpi 38792 Dec 10 22:59 Microsoft.Extensions.Primitives.dll
-rw-r--r-- 1 radarr dietpi 30600 Dec 10 22:59 Microsoft.Extensions.WebEncoders.dll
-rw-r--r-- 1 radarr dietpi 96136 Dec 10 22:59 Microsoft.JSInterop.dll
-rw-r--r-- 1 radarr dietpi 249736 Dec 10 22:59 Microsoft.Net.Http.Headers.dll
-rw-r--r-- 1 radarr dietpi 1492360 Dec 10 22:59 Microsoft.VisualBasic.Core.dll
-rw-r--r-- 1 radarr dietpi 17280 Dec 10 22:59 Microsoft.VisualBasic.dll
-rw-r--r-- 1 radarr dietpi 21896 Dec 10 22:59 Microsoft.Win32.Primitives.dll
-rw-r--r-- 1 radarr dietpi 68488 Dec 10 22:59 Microsoft.Win32.Registry.dll
-rw-r--r-- 1 radarr dietpi 23112 Dec 10 22:59 Microsoft.Win32.SystemEvents.dll
-rw-r--r-- 1 radarr dietpi 64000 Dec 10 22:59 Mono.Nat.dll
-rw-r--r-- 1 radarr dietpi 190080 Dec 10 22:59 Mono.Posix.NETStandard.dll
-rw-r--r-- 1 radarr dietpi 556544 Dec 10 22:59 MonoTorrent.dll
-rw-r--r-- 1 radarr dietpi 56704 Dec 10 22:59 mscorlib.dll
-rw-r--r-- 1 radarr dietpi 8704 Dec 10 22:59 Nancy.Authentication.Basic.dll
-rw-r--r-- 1 radarr dietpi 13824 Dec 10 22:59 Nancy.Authentication.Forms.dll
-rw-r--r-- 1 radarr dietpi 919552 Dec 10 22:59 Nancy.dll
-rw-r--r-- 1 radarr dietpi 114568 Dec 10 22:59 netstandard.dll
-rw-r--r-- 1 radarr dietpi 693680 Dec 10 22:59 Newtonsoft.Json.dll
-rw-r--r-- 1 radarr dietpi 803328 Dec 10 22:59 NLog.dll
-rw-r--r-- 1 radarr dietpi 45056 Dec 10 22:59 NLog.Extensions.Logging.dll
-rw-r--r-- 1 radarr dietpi 436224 Dec 10 22:59 NodaTime.dll
-rw-r--r-- 1 radarr dietpi 28672 Dec 10 22:59 Org.Mentalis.dll
-rwxr-xr-x 1 radarr dietpi 135968 Dec 10 22:59 Radarr
-rw-r--r-- 1 radarr dietpi 137206 Dec 10 22:59 Radarr.Api.deps.json
-rw-r--r-- 1 radarr dietpi 192000 Dec 10 22:59 Radarr.Api.dll
-rw-r--r-- 1 radarr dietpi 78424 Dec 10 22:59 Radarr.Api.pdb
-rw-r--r-- 1 radarr dietpi 137243 Dec 10 22:59 Radarr.Api.V3.deps.json
-rw-r--r-- 1 radarr dietpi 261120 Dec 10 22:59 Radarr.Api.V3.dll
-rw-r--r-- 1 radarr dietpi 98392 Dec 10 22:59 Radarr.Api.V3.pdb
-rw-r--r-- 1 radarr dietpi 45799 Dec 10 22:59 Radarr.Common.deps.json
-rw-r--r-- 1 radarr dietpi 271360 Dec 10 22:59 Radarr.Common.dll
-rw-r--r-- 1 radarr dietpi 108832 Dec 10 22:59 Radarr.Common.pdb
-rw-r--r-- 1 radarr dietpi 58908 Dec 10 22:59 Radarr.Core.deps.json
-rw-r--r-- 1 radarr dietpi 1819648 Dec 10 22:59 Radarr.Core.dll
-rw-r--r-- 1 radarr dietpi 356 Dec 10 22:59 Radarr.Core.dll.config
-rw-r--r-- 1 radarr dietpi 633156 Dec 10 22:59 Radarr.Core.pdb
-rw-r--r-- 1 radarr dietpi 193154 Dec 10 22:59 Radarr.deps.json
-rw-r--r-- 1 radarr dietpi 119296 Dec 10 22:59 Radarr.dll
-rw-r--r-- 1 radarr dietpi 431 Dec 10 22:59 Radarr.dll.config
-rw-r--r-- 1 radarr dietpi 313190 Dec 10 22:59 Radarr.Host.deps.json
-rw-r--r-- 1 radarr dietpi 33280 Dec 10 22:59 Radarr.Host.dll
-rw-r--r-- 1 radarr dietpi 29008 Dec 10 22:59 Radarr.Host.pdb
-rw-r--r-- 1 radarr dietpi 132351 Dec 10 22:59 Radarr.Http.deps.json
-rw-r--r-- 1 radarr dietpi 86016 Dec 10 22:59 Radarr.Http.dll
-rw-r--r-- 1 radarr dietpi 47900 Dec 10 22:59 Radarr.Http.pdb
-rw-r--r-- 1 radarr dietpi 46978 Dec 10 22:59 Radarr.Mono.deps.json
-rw-r--r-- 1 radarr dietpi 26624 Dec 10 22:59 Radarr.Mono.dll
-rw-r--r-- 1 radarr dietpi 20868 Dec 10 22:59 Radarr.Mono.pdb
-rw-r--r-- 1 radarr dietpi 21536 Dec 10 22:59 Radarr.pdb
-rw-r--r-- 1 radarr dietpi 279 Dec 10 22:59 Radarr.runtimeconfig.json
-rw-r--r-- 1 radarr dietpi 182696 Dec 10 22:59 Radarr.SignalR.deps.json
-rw-r--r-- 1 radarr dietpi 9216 Dec 10 22:59 Radarr.SignalR.dll
-rw-r--r-- 1 radarr dietpi 20820 Dec 10 22:59 Radarr.SignalR.pdb
drwxr-xr-x 2 radarr dietpi 20480 Dec 10 22:59 Radarr.Update
-rw-r--r-- 1 radarr dietpi 21504 Dec 10 22:59 ReusableTasks.dll
-rw-r--r-- 1 radarr dietpi 85504 Dec 10 22:59 Sentry.dll
-rw-r--r-- 1 radarr dietpi 11264 Dec 10 22:59 Sentry.PlatformAbstractions.dll
-rw-r--r-- 1 radarr dietpi 50688 Dec 10 22:59 Sentry.Protocol.dll
-rw-r--r-- 1 radarr dietpi 135968 Dec 10 22:59 ServiceInstall
-rw-r--r-- 1 radarr dietpi 135968 Dec 10 22:59 ServiceUninstall
-rw-r--r-- 1 radarr dietpi 1148928 Dec 10 22:59 SixLabors.ImageSharp.dll
-rw-r--r-- 1 radarr dietpi 10752 Dec 10 22:59 SocksWebProxy.dll
-rw-r--r-- 1 radarr dietpi 272 Dec 10 22:59 SOS_README.md
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.AppContext.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Buffers.dll
-rw-r--r-- 1 radarr dietpi 228736 Dec 10 22:59 System.Collections.Concurrent.dll
-rw-r--r-- 1 radarr dietpi 416128 Dec 10 22:59 System.Collections.dll
-rw-r--r-- 1 radarr dietpi 828808 Dec 10 22:59 System.Collections.Immutable.dll
-rw-r--r-- 1 radarr dietpi 118152 Dec 10 22:59 System.Collections.NonGeneric.dll
-rw-r--r-- 1 radarr dietpi 109960 Dec 10 22:59 System.Collections.Specialized.dll
-rw-r--r-- 1 radarr dietpi 198016 Dec 10 22:59 System.ComponentModel.Annotations.dll
-rw-r--r-- 1 radarr dietpi 16264 Dec 10 22:59 System.ComponentModel.DataAnnotations.dll
-rw-r--r-- 1 radarr dietpi 16776 Dec 10 22:59 System.ComponentModel.dll
-rw-r--r-- 1 radarr dietpi 39304 Dec 10 22:59 System.ComponentModel.EventBasedAsync.dll
-rw-r--r-- 1 radarr dietpi 63368 Dec 10 22:59 System.ComponentModel.Primitives.dll
-rw-r--r-- 1 radarr dietpi 886144 Dec 10 22:59 System.ComponentModel.TypeConverter.dll
-rw-r--r-- 1 radarr dietpi 375912 Dec 10 22:59 System.Configuration.ConfigurationManager.dll
-rw-r--r-- 1 radarr dietpi 19336 Dec 10 22:59 System.Configuration.dll
-rw-r--r-- 1 radarr dietpi 224136 Dec 10 22:59 System.Console.dll
-rw-r--r-- 1 radarr dietpi 23944 Dec 10 22:59 System.Core.dll
-rw-r--r-- 1 radarr dietpi 3758976 Dec 10 22:59 System.Data.Common.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Data.DataSetExtensions.dll
-rw-r--r-- 1 radarr dietpi 25992 Dec 10 22:59 System.Data.dll
-rw-r--r-- 1 radarr dietpi 351744 Dec 10 22:59 System.Data.SQLite.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Diagnostics.Contracts.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Diagnostics.Debug.dll
-rw-r--r-- 1 radarr dietpi 117640 Dec 10 22:59 System.Diagnostics.DiagnosticSource.dll
-rw-r--r-- 1 radarr dietpi 49256 Dec 10 22:59 System.Diagnostics.EventLog.dll
-rw-r--r-- 1 radarr dietpi 40840 Dec 10 22:59 System.Diagnostics.FileVersionInfo.dll
-rw-r--r-- 1 radarr dietpi 273288 Dec 10 22:59 System.Diagnostics.Process.dll
-rw-r--r-- 1 radarr dietpi 37768 Dec 10 22:59 System.Diagnostics.StackTrace.dll
-rw-r--r-- 1 radarr dietpi 67976 Dec 10 22:59 System.Diagnostics.TextWriterTraceListener.dll
-rw-r--r-- 1 radarr dietpi 17800 Dec 10 22:59 System.Diagnostics.Tools.dll
-rw-r--r-- 1 radarr dietpi 157576 Dec 10 22:59 System.Diagnostics.TraceSource.dll
-rw-r--r-- 1 radarr dietpi 15752 Dec 10 22:59 System.Diagnostics.Tracing.dll
-rw-r--r-- 1 radarr dietpi 54664 Dec 10 22:59 System.dll
-rw-r--r-- 1 radarr dietpi 372840 Dec 10 22:59 System.Drawing.Common.dll
-rw-r--r-- 1 radarr dietpi 20864 Dec 10 22:59 System.Drawing.dll
-rw-r--r-- 1 radarr dietpi 136064 Dec 10 22:59 System.Drawing.Primitives.dll
-rw-r--r-- 1 radarr dietpi 15752 Dec 10 22:59 System.Dynamic.Runtime.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Globalization.Calendars.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Globalization.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Globalization.Extensions.dll
-rw-r--r-- 1 radarr dietpi 59288 Dec 10 22:59 System.Globalization.Native.so
-rw-r--r-- 1 radarr dietpi 80776 Dec 10 22:59 System.IO.Compression.Brotli.dll
-rw-r--r-- 1 radarr dietpi 302984 Dec 10 22:59 System.IO.Compression.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.IO.Compression.FileSystem.dll
-rw-r--r-- 1 radarr dietpi 3042390 Dec 10 22:59 System.IO.Compression.Native.a
-rw-r--r-- 1 radarr dietpi 723864 Dec 10 22:59 System.IO.Compression.Native.so
-rw-r--r-- 1 radarr dietpi 38280 Dec 10 22:59 System.IO.Compression.ZipFile.dll
-rw-r--r-- 1 radarr dietpi 15232 Dec 10 22:59 System.IO.dll
-rw-r--r-- 1 radarr dietpi 35208 Dec 10 22:59 System.IO.FileSystem.AccessControl.dll
-rw-r--r-- 1 radarr dietpi 262016 Dec 10 22:59 System.IO.FileSystem.dll
-rw-r--r-- 1 radarr dietpi 84872 Dec 10 22:59 System.IO.FileSystem.DriveInfo.dll
-rw-r--r-- 1 radarr dietpi 14720 Dec 10 22:59 System.IO.FileSystem.Primitives.dll
-rw-r--r-- 1 radarr dietpi 109960 Dec 10 22:59 System.IO.FileSystem.Watcher.dll
-rw-r--r-- 1 radarr dietpi 92040 Dec 10 22:59 System.IO.IsolatedStorage.dll
-rw-r--r-- 1 radarr dietpi 79240 Dec 10 22:59 System.IO.MemoryMappedFiles.dll
-rw-r--r-- 1 radarr dietpi 65928 Dec 10 22:59 System.IO.Pipelines.dll
-rw-r--r-- 1 radarr dietpi 24968 Dec 10 22:59 System.IO.Pipes.AccessControl.dll
-rw-r--r-- 1 radarr dietpi 141192 Dec 10 22:59 System.IO.Pipes.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.IO.UnmanagedMemoryStream.dll
-rw-r--r-- 1 radarr dietpi 519048 Dec 10 22:59 System.Linq.dll
-rw-r--r-- 1 radarr dietpi 7621000 Dec 10 22:59 System.Linq.Expressions.dll
-rw-r--r-- 1 radarr dietpi 1665408 Dec 10 22:59 System.Linq.Parallel.dll
-rw-r--r-- 1 radarr dietpi 240008 Dec 10 22:59 System.Linq.Queryable.dll
-rw-r--r-- 1 radarr dietpi 225672 Dec 10 22:59 System.Memory.dll
-rw-r--r-- 1 radarr dietpi 461328 Dec 10 22:59 System.Native.a
-rw-r--r-- 1 radarr dietpi 69296 Dec 10 22:59 System.Native.so
-rw-r--r-- 1 radarr dietpi 16776 Dec 10 22:59 System.Net.dll
-rw-r--r-- 1 radarr dietpi 1837448 Dec 10 22:59 System.Net.Http.dll
-rw-r--r-- 1 radarr dietpi 379784 Dec 10 22:59 System.Net.HttpListener.dll
-rw-r--r-- 1 radarr dietpi 84684 Dec 10 22:59 System.Net.Http.Native.a
-rw-r--r-- 1 radarr dietpi 68256 Dec 10 22:59 System.Net.Http.Native.so
-rw-r--r-- 1 radarr dietpi 621960 Dec 10 22:59 System.Net.Mail.dll
-rw-r--r-- 1 radarr dietpi 96136 Dec 10 22:59 System.Net.NameResolution.dll
-rw-r--r-- 1 radarr dietpi 196992 Dec 10 22:59 System.Net.NetworkInformation.dll
-rw-r--r-- 1 radarr dietpi 131976 Dec 10 22:59 System.Net.Ping.dll
-rw-r--r-- 1 radarr dietpi 272264 Dec 10 22:59 System.Net.Primitives.dll
-rw-r--r-- 1 radarr dietpi 430976 Dec 10 22:59 System.Net.Requests.dll
-rw-r--r-- 1 radarr dietpi 757128 Dec 10 22:59 System.Net.Security.dll
-rw-r--r-- 1 radarr dietpi 40170 Dec 10 22:59 System.Net.Security.Native.a
-rw-r--r-- 1 radarr dietpi 68264 Dec 10 22:59 System.Net.Security.Native.so
-rw-r--r-- 1 radarr dietpi 36744 Dec 10 22:59 System.Net.ServicePoint.dll
-rw-r--r-- 1 radarr dietpi 748936 Dec 10 22:59 System.Net.Sockets.dll
-rw-r--r-- 1 radarr dietpi 191880 Dec 10 22:59 System.Net.WebClient.dll
-rw-r--r-- 1 radarr dietpi 82312 Dec 10 22:59 System.Net.WebHeaderCollection.dll
-rw-r--r-- 1 radarr dietpi 29568 Dec 10 22:59 System.Net.WebProxy.dll
-rw-r--r-- 1 radarr dietpi 83336 Dec 10 22:59 System.Net.WebSockets.Client.dll
-rw-r--r-- 1 radarr dietpi 167816 Dec 10 22:59 System.Net.WebSockets.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Numerics.dll
-rw-r--r-- 1 radarr dietpi 154496 Dec 10 22:59 System.Numerics.Vectors.dll
-rw-r--r-- 1 radarr dietpi 105856 Dec 10 22:59 System.ObjectModel.dll
-rw-r--r-- 1 radarr dietpi 11440520 Dec 10 22:59 System.Private.CoreLib.dll
-rw-r--r-- 1 radarr dietpi 2621320 Dec 10 22:59 System.Private.DataContractSerialization.dll
-rw-r--r-- 1 radarr dietpi 285064 Dec 10 22:59 System.Private.Uri.dll
-rw-r--r-- 1 radarr dietpi 10656128 Dec 10 22:59 System.Private.Xml.dll
-rw-r--r-- 1 radarr dietpi 462720 Dec 10 22:59 System.Private.Xml.Linq.dll
-rw-r--r-- 1 radarr dietpi 82816 Dec 10 22:59 System.Reflection.DispatchProxy.dll
-rw-r--r-- 1 radarr dietpi 15744 Dec 10 22:59 System.Reflection.dll
-rw-r--r-- 1 radarr dietpi 15232 Dec 10 22:59 System.Reflection.Emit.dll
-rw-r--r-- 1 radarr dietpi 15232 Dec 10 22:59 System.Reflection.Emit.ILGeneration.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Reflection.Emit.Lightweight.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Reflection.Extensions.dll
-rw-r--r-- 1 radarr dietpi 1287560 Dec 10 22:59 System.Reflection.Metadata.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Reflection.Primitives.dll
-rw-r--r-- 1 radarr dietpi 33160 Dec 10 22:59 System.Reflection.TypeExtensions.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Resources.Reader.dll
-rw-r--r-- 1 radarr dietpi 15232 Dec 10 22:59 System.Resources.ResourceManager.dll
-rw-r--r-- 1 radarr dietpi 49032 Dec 10 22:59 System.Resources.Writer.dll
-rw-r--r-- 1 radarr dietpi 18824 Dec 10 22:59 System.Runtime.CompilerServices.Unsafe.dll
-rw-r--r-- 1 radarr dietpi 18312 Dec 10 22:59 System.Runtime.CompilerServices.VisualC.dll
-rw-r--r-- 1 radarr dietpi 55176 Dec 10 22:59 System.Runtime.dll
-rw-r--r-- 1 radarr dietpi 250752 Dec 10 22:59 System.Runtime.Extensions.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Runtime.Handles.dll
-rw-r--r-- 1 radarr dietpi 58760 Dec 10 22:59 System.Runtime.InteropServices.dll
-rw-r--r-- 1 radarr dietpi 28544 Dec 10 22:59 System.Runtime.InteropServices.RuntimeInformation.dll
-rw-r--r-- 1 radarr dietpi 25480 Dec 10 22:59 System.Runtime.InteropServices.WindowsRuntime.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Runtime.Intrinsics.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Runtime.Loader.dll
-rw-r--r-- 1 radarr dietpi 225672 Dec 10 22:59 System.Runtime.Numerics.dll
-rw-r--r-- 1 radarr dietpi 16776 Dec 10 22:59 System.Runtime.Serialization.dll
-rw-r--r-- 1 radarr dietpi 379272 Dec 10 22:59 System.Runtime.Serialization.Formatters.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Runtime.Serialization.Json.dll
-rw-r--r-- 1 radarr dietpi 27528 Dec 10 22:59 System.Runtime.Serialization.Primitives.dll
-rw-r--r-- 1 radarr dietpi 16256 Dec 10 22:59 System.Runtime.Serialization.Xml.dll
-rw-r--r-- 1 radarr dietpi 51080 Dec 10 22:59 System.Runtime.WindowsRuntime.dll
-rw-r--r-- 1 radarr dietpi 54656 Dec 10 22:59 System.Runtime.WindowsRuntime.UI.Xaml.dll
-rw-r--r-- 1 radarr dietpi 83840 Dec 10 22:59 System.Security.AccessControl.dll
-rw-r--r-- 1 radarr dietpi 104840 Dec 10 22:59 System.Security.Claims.dll
-rw-r--r-- 1 radarr dietpi 793480 Dec 10 22:59 System.Security.Cryptography.Algorithms.dll
-rw-r--r-- 1 radarr dietpi 80264 Dec 10 22:59 System.Security.Cryptography.Cng.dll
-rw-r--r-- 1 radarr dietpi 136072 Dec 10 22:59 System.Security.Cryptography.Csp.dll
-rw-r--r-- 1 radarr dietpi 86920 Dec 10 22:59 System.Security.Cryptography.Encoding.dll
-rw-r--r-- 1 radarr dietpi 1027120 Dec 10 22:59 System.Security.Cryptography.Native.OpenSsl.a
-rw-r--r-- 1 radarr dietpi 133912 Dec 10 22:59 System.Security.Cryptography.Native.OpenSsl.so
-rw-r--r-- 1 radarr dietpi 231816 Dec 10 22:59 System.Security.Cryptography.OpenSsl.dll
-rw-r--r-- 1 radarr dietpi 933256 Dec 10 22:59 System.Security.Cryptography.Pkcs.dll
-rw-r--r-- 1 radarr dietpi 121224 Dec 10 22:59 System.Security.Cryptography.Primitives.dll
-rw-r--r-- 1 radarr dietpi 17784 Dec 10 22:59 System.Security.Cryptography.ProtectedData.dll
-rw-r--r-- 1 radarr dietpi 748424 Dec 10 22:59 System.Security.Cryptography.X509Certificates.dll
-rw-r--r-- 1 radarr dietpi 544136 Dec 10 22:59 System.Security.Cryptography.Xml.dll
-rw-r--r-- 1 radarr dietpi 17792 Dec 10 22:59 System.Security.dll
-rw-r--r-- 1 radarr dietpi 92536 Dec 10 22:59 System.Security.Permissions.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Security.Principal.dll
-rw-r--r-- 1 radarr dietpi 45960 Dec 10 22:59 System.Security.Principal.Windows.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Security.SecureString.dll
-rw-r--r-- 1 radarr dietpi 119160 Dec 10 22:59 System.ServiceModel.Syndication.dll
-rw-r--r-- 1 radarr dietpi 16256 Dec 10 22:59 System.ServiceModel.Web.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.ServiceProcess.dll
-rw-r--r-- 1 radarr dietpi 30584 Dec 10 22:59 System.ServiceProcess.ServiceController.dll
-rw-r--r-- 1 radarr dietpi 899976 Dec 10 22:59 System.Text.Encoding.CodePages.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Text.Encoding.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Text.Encoding.Extensions.dll
-rw-r--r-- 1 radarr dietpi 115080 Dec 10 22:59 System.Text.Encodings.Web.dll
-rw-r--r-- 1 radarr dietpi 1013128 Dec 10 22:59 System.Text.Json.dll
-rw-r--r-- 1 radarr dietpi 500616 Dec 10 22:59 System.Text.RegularExpressions.dll
-rw-r--r-- 1 radarr dietpi 135560 Dec 10 22:59 System.Threading.Channels.dll
-rw-r--r-- 1 radarr dietpi 91016 Dec 10 22:59 System.Threading.dll
-rw-r--r-- 1 radarr dietpi 16256 Dec 10 22:59 System.Threading.Overlapped.dll
-rw-r--r-- 1 radarr dietpi 591240 Dec 10 22:59 System.Threading.Tasks.Dataflow.dll
-rw-r--r-- 1 radarr dietpi 16264 Dec 10 22:59 System.Threading.Tasks.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Threading.Tasks.Extensions.dll
-rw-r--r-- 1 radarr dietpi 129928 Dec 10 22:59 System.Threading.Tasks.Parallel.dll
-rw-r--r-- 1 radarr dietpi 17800 Dec 10 22:59 System.Threading.Thread.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Threading.ThreadPool.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Threading.Timer.dll
-rw-r--r-- 1 radarr dietpi 16264 Dec 10 22:59 System.Transactions.dll
-rw-r--r-- 1 radarr dietpi 424840 Dec 10 22:59 System.Transactions.Local.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.ValueTuple.dll
-rw-r--r-- 1 radarr dietpi 14728 Dec 10 22:59 System.Web.dll
-rw-r--r-- 1 radarr dietpi 53128 Dec 10 22:59 System.Web.HttpUtility.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Windows.dll
-rw-r--r-- 1 radarr dietpi 25976 Dec 10 22:59 System.Windows.Extensions.dll
-rw-r--r-- 1 radarr dietpi 24456 Dec 10 22:59 System.Xml.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Xml.Linq.dll
-rw-r--r-- 1 radarr dietpi 22408 Dec 10 22:59 System.Xml.ReaderWriter.dll
-rw-r--r-- 1 radarr dietpi 15752 Dec 10 22:59 System.Xml.Serialization.dll
-rw-r--r-- 1 radarr dietpi 15240 Dec 10 22:59 System.Xml.XDocument.dll
-rw-r--r-- 1 radarr dietpi 15752 Dec 10 22:59 System.Xml.XmlDocument.dll
-rw-r--r-- 1 radarr dietpi 17800 Dec 10 22:59 System.Xml.XmlSerializer.dll
-rw-r--r-- 1 radarr dietpi 15232 Dec 10 22:59 System.Xml.XPath.dll
-rw-r--r-- 1 radarr dietpi 16776 Dec 10 22:59 System.Xml.XPath.XDocument.dll
drwxr-xr-x 3 radarr dietpi 4096 Dec 10 22:59 UI
-rw-r--r-- 1 radarr dietpi 558 Dec 10 22:59 web.config
-rw-r--r-- 1 radarr dietpi 15752 Dec 10 22:59 WindowsBase.dll
Post
by Joulinar » Wed Dec 23, 2020 12:41 am
looks like Radarr executable is there. But you are still not able to have it started manually?
JuniorChange
Post
by JuniorChange » Wed Dec 23, 2020 12:44 am
No its kind of weird says its not there
Post
by Joulinar » Wed Dec 23, 2020 1:03 pm
that's quite strange. can you move inside the directory and try to execute Radarr
JuniorChange
Post
by JuniorChange » Wed Dec 23, 2020 10:55 pm
No I cannot
root@DietPi:~# cd /opt/radarr/
root@DietPi:/opt/radarr# ./Radarr
-bash: ./Radarr: No such file or directory
Even though when I
ls i see the Radarr executable
Post
by Joulinar » Wed Dec 23, 2020 11:03 pm
I don't get it how this should be possible
Did you tried to remove radarr completely and perform a new installation?
JuniorChange
Post
by JuniorChange » Wed Dec 23, 2020 11:09 pm
Uninstalled, rebooted and reinstalled multiple times. Might just have to fresh install but I want that as the last resort, have any other ideas?
Post
by Joulinar » Wed Dec 23, 2020 11:14 pm
last try. Go inside the radarr directory
and just type
./Rad
Than use TAB to complete the command. Usually it should compete automatically to
./Radarr
