Change permissions to mounted ntfs drive Topic is solved
Re: Change permissions to mounted ntfs drive
if you run it from gui it should stop if you close SSH session. But you could schedule a daily job
Yes, I set daily job for that sync. Thanks for help.
Regards,
Przemek
Regards,
Przemek
