Change permissions to mounted ntfs drive Topic is solved
Re: Change permissions to mounted ntfs drive
that's how you export files systems usually using NFS
@Joulinar but if I don't have any entry here it shouldn't pass everyone?
I can mount that drive in nautilus as `sftp://192.168.0.24:/mnt/Seagate` but when I set that address in deja-dup to make backup it don't work.
regards.
regards.
If you don't have any entry, how will the system know what do you want to share? It is a huge security risk to "just allow everything".
But It's only in my local home network. My first drive works without any entry.
regards.
regards.
now I'm confused. Do you try to use SFTP or NFS?
@Joulinar I want to use nfs mount on both drives. Now when I add entry to /ect/exports my Toshiba stop working on Ubutnu. I cannot access to /mnt/ folder on laptop.
I try sfp to check it working.
regards.
root@DietPi:/# cat /etc/exports
# /etc/exports: the access control list for filesystems which may be exported
# to NFS clients. See exports(5).
# Example for NFSv2 and NFSv3:
# /srv/homes hostname1(rw,sync,no_subtree_check) hostname2(ro,sync,no_subtree_check)
# Example for NFSv4:
# /srv/nfs4 gss/krb5i(rw,sync,fsid=0,crossmnt,no_subtree_check)
# /srv/nfs4/homes gss/krb5i(rw,sync,no_subtree_check)
/mnt/Seagate 192.168.0.*(rw,async,no_root_squash,fsid=0,crossmnt,no_subtree_check)
/mnt/Toshiba 192.168.0.*(rw,async,no_root_squash,fsid=0,crossmnt,no_subtree_check)
regards.
When I reboot ubuntu lapton situation is even weirder. I have two times mounted that new drive. In /mnt/nas and in /mnt/Seagate.
How is that possible?
lusia@lusia-laptop:~$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda2 during installation
UUID=07177a55-7bea-434d-876f-fe8550dec6ad / ext4 errors=remount-ro 0 1
# /home was on /dev/sda3 during installation
UUID=27a6b203-1463-484d-b0b1-e29056ec074b /home ext4 defaults 0 2
# swap was on /dev/sda4 during installation
UUID=44edea65-65b0-484c-a846-8f992e5e890e none swap sw 0 0
# <file system> <dir> <type> <options> <dump> <pass>
192.168.0.24:/mnt/Toshiba/dietpi_userdata /mnt/nas nfs defaults 0 0
192.168.0.24:/mnt/Seagate /mnt/Seagate nfs defaults 0 0
Which is logical as the root directories are /mnt/Toshiba and /mnt/Seagate
SFTP has nothing to do with NFS.
An example of the fstab entry in the NFS client is:
10.0.2.5:/ /mnt/backup nfs _netdev,nofail,noauto,x-systemd.automount
Hi @trendy, can You tell me how it's possible that when I do:
`sudo mount -t nfs 192.168.0.24:/mnt/Toshiba/dietpi_userdata/ /mnt/nas/` my laptop mount me my second Seagate drive in /mnt/nas. While /mnt/Seagate from Dietpi is mounted in /mnt/Seagate in ubuntu?
OK, I find error. I have the same fsid=0 in /etc/exports
regards.
regards.
Hi, one more thing @Joulinar. I start dietpi-sync now in my EasySSH terminal on ubuntu laptop. Can You tell me if I close that application window my sync will continue? Because when I copy folders in midnight commander it stops.
Regards.
Regards.
