fastcgi-problem with dietpi x86 lighttpd nextcloud collabora [solved]
Re: fastcgi-problem with dietpi x86 lighttpd nextcloud collabora [solved]
The fix (config change) should not required anymore as the underlying bug has been solved in the Debian package. At least when it's the same underlying issue that caused logout to fail with Lighttpd and that was fixed with the same config change :?.
On my test it is working OOTB, without any fix :)
