No space left on sd-card Topic is solved
przemko
Re: No space left on sd-card
Post by przemko »
Do You mean like this?
-rw------- 1 www-data www-data 1055736 Dec 10 13:42 lighttpd-upload-zxI5lq
-rw------- 1 www-data www-data 1051638 Dec 10 14:23 lighttpd-upload-zxVAjA
-rw------- 1 www-data www-data 1055736 Dec 10 13:46 lighttpd-upload-zxZ3LE
-rw------- 1 www-data www-data 1055736 Dec 10 14:05 lighttpd-upload-zxzGch
-rw------- 1 www-data www-data 1055736 Dec 10 14:14 lighttpd-upload-zy1FAX
-rw------- 1 www-data www-data 1055736 Dec 10 13:51 lighttpd-upload-zyU4VL
-rw------- 1 www-data www-data 1055736 Dec 10 13:46 lighttpd-upload-zylw4W
-rw------- 1 www-data www-data 1055736 Dec 10 13:47 lighttpd-upload-zyvupF
-rw------- 1 www-data www-data 1055736 Dec 10 14:08 lighttpd-upload-zzOfK7
-rw------- 1 www-data www-data 1055736 Dec 10 14:03 lighttpd-upload-zza1Il
-rw------- 1 www-data www-data 1055736 Dec 10 13:53 lighttpd-upload-zzlB8Y
-rw------- 1 www-data www-data 1055736 Dec 10 13:49 lighttpd-upload-zzmyrQ
I think it's my foult because I play with my Nextcloud webdav protocol. I use it rclone webgui and try to munt it on my archlinux laptop in work.
Do You think move `/rootfs` to my HDD `/mnt/Toshiba` where I have `/dietpi_userdata` will help?
moving RootFS will format the target device. So not a good idea ;) viewtopic.php?p=22717#p22717
you could try to remove these cache files to gain space on your SD card.
przemko
Post by przemko »
Joulinar wrote: Thu Dec 10, 2020 10:24 pm you could try to remove these cache files to gain space on your SD card.
Hi, I remove those files and for now everything is OK but I'm afraid that it will be full after some time again. I must check in work that webdav, rclone and rsync connections I try yesterday.
Regards.
usually cache files should be deleted once upload was done. Maybe you need to watch it closely for the next time
przemko
Post by przemko »
Hi @Joulinar today when I look at sd-card space it's 96% used from 29GB. That `/var/cache/lighttpd/uploads/` folder is also full. I delete every file again :/
I have notice when I reinstall nextcloud that there's old lighttpd installation present maybe this is problem?
Regards,
Przemek
what do you mean by an old lighttpd instance? lighttpd can be installed only once.
Maybe it would make sense to check on a NextCloud specialised board regarding the cache issue and why files did not get deleted automatically.
przemko
Post by przemko »
Joulinar wrote: Fri Dec 11, 2020 10:36 pm what do you mean by an old lighttpd instance? lighttpd can be installed only once.
I mean when I reinstall nextcloud at the end I get information that there's old lighttpd configuration on system and will be saved as lighttpd...old or something like that.
Joulinar wrote: Fri Dec 11, 2020 10:36 pm Maybe it would make sense to check on a NextCloud specialised board regarding the cache issue and why files did not get deleted automatically.
OK, I will post on some nextcloud forum.
Thanks for Your time and help.
Regards.
Przemek
