Not able to install SqueezeLite (Broken Packages) Topic is solved
Re: Not able to install SqueezeLite (Broken Packages)
Yes the Buster Allo image was created beginning of November. So might be it was not updated so far. I guess influence from DietPi side into these products are limited.
Anyway. If you have a windows desktop, use win32diskimager to create an .img file of your SD card as backup. Once done, just flash the Allo Buster image using balenaEtcher. Hopefully this will fix your issue.
maxpi
Post by maxpi »
Hi Joulinar! Thanks a lot for your help.
I will try your suggestion and come back.
By the way, I'm using OS X, but I guess that it won't be a problem.
Again, thanks.
maxpi
Post by maxpi »
Hi Joulinar!
I tried what you said and everything is going well!!
(Though I still don't know what happened with the other system were I couldn't reinstall Squeezelite)
Thanks!
hi,
issue was that Raspberry OS Stretch did not provide the correct version of libmpg123-0, needed to be able to install SqueezeLite. Now as you are on Raspberry OS Buster the issue is gone as Buster provide a newer version :)
