[FAILED] Country code "IT" could not been applied.
Please check the country code and try again.
If problems persist, this may be a limitation with the driver/chipset.
root@DietPi4:~# dietpi-config
[ SUB2 ] DietPi-Set_hardware > wificountrycode (it)
[ OK ] DietPi-Set_hardware | Setting in /etc/default/crda adjusted: REGDOMAIN=IT
[ OK ] DietPi-Set_hardware | Setting in /boot/dietpi.txt adjusted: AUTO_SETUP_NET_WIFI_COUNTRY_CODE=IT
[ OK ] wificountrycode IT | Completed
[ SUB2 ] DietPi-Services > stop
[ OK ] DietPi-Services | stop : cron
[ SUB2 ] DietPi-Set_hardware > wifimodules (enable)
[ INFO ] DietPi-Set_hardware | Please wait, enabling WiFi modules...
[ INFO ] DietPi-Set_hardware | Checking for required APT packages: iw wireless-tools crda wpasupplicant
[ OK ] DietPi-Set_hardware | All required APT packages are already installed.
[ OK ] wifimodules enable | Completed
[ OK ] DietPi-Config | Dropping connections, please wait...
[ INFO ] DietPi-Config | Restarting network, please wait...
[ SUB2 ] DietPi-Services > start
[ OK ] DietPi-Services | start : cron
[ INFO ] DietPi-Config | Reloading networking data, please wait...
[ OK ] DietPi-Config | Network restarted
