DietPi Specific VPN with PiHole Gateway Guide?
rothchild
Re: DietPi Specific VPN with PiHole Gateway Guide?
Post by rothchild »
Joulinar wrote: Wed Dec 02, 2020 5:19 pm Don't change the gateway on your internet router. It's still providing the internet access. You would need to set the gateway on your client system like windows. ;)
Thanks, I finally worked that out myself. Seems a lot of the issue I (thought ) I was having was because I couldn't get the gateway settings to stick on my linux laptop, seems it was easier (for once) on a windows box. Once I got that working things started to fall in to place (although im still not sure whether my DNS queries are being routed out over the VPN, and I'm not sure how to check!)
check on your DietPi device by doing at traceroute to Google dns or Quad9. This should show you the way how it's going
traceroute 8.8.8.8
it might be needed to install traceroute before
apt install traceroute
