Aria2 WebUI not loading Topic is solved
Wishmaster.dj
Re: Aria2 WebUI not loading
Post by Wishmaster.dj »
No luck yet. Still get the saem Pi-hole image redirection message. Do you think suspect Pi-hole to be interfering with this? Should I uninstall Pi-hole?
Usually it should work. At least on my test it was working well to have PiHole as well as Aria2 running on some system. The web site you get displayed is more the error handle that get shown if the page is not reachable.
Anyway you can give it a try and remove PiHole. But keep in mind, atm your local devices are configured to use PiHole as DNS server and if PiHole is missing, it might can cause challenges ;) Might be needed to use your internet router during the absence of PiHole
Wishmaster.dj
Reinstalled the entire OS from scratch and it works now! Was probably a case of some corrupt file/conflict.
Thanks!
probably something mixed up on config files but good that it is working now
