Will DietPi work on the NanoPi R2S Topic is solved
forevergreen
Re: Will DietPi work on the NanoPi R2S
Post by forevergreen »
Joulinar wrote: Tue Nov 17, 2020 12:27 pm Hi,
you simple can give it a try. You will recognise it soon if it is not working ;)
Another option is to use an Armbian Buster image https://www.armbian.com/nanopi-r2s/
and trans form it into DietPi using PREP script https://github.com/MichaIng/DietPi/issues/1285
Whats special about Armbian, I thought DietPi is as small as it comes. Aren't all RPi distros ARM based anyway?
DietPi is not an own OS or destro. DietPi is a set of scripts on top of a base image. Depending on your SBC, different base images are used. We use Armbian, Mavaric, plain Debian and Raspberry OS.
No sorry, I'm out of ideas how to get that working on R2S.
On RPi, the Argon One script seems to setup a custom PWM control via GPIO pins, a Python script. That is above what I can help with. But as general debugging:
- The script ran through without any error?
- The following command has been installed which might allow to re-configure the fan: argonone-config
- And a service has been installed. Could you check it's state and output:
systemctl status argononed
journalctl -u argononed
forevergreen
Joulinar wrote: Tue Mar 02, 2021 9:17 am DietPi is not an own OS or destro. DietPi is a set of scripts on top of a base image. Depending on your SBC, different base images are used. We use Armbian, Mavaric, plain Debian and Raspberry OS.
Oh, I thought DietPi is its own distro modified from Raspbian.
It's a question where you draw the line from what an own distro/OS is. Relevant is that DietPi does no own kernel development, hence uses kernel packages from 3rd party developers (Armbian in case of NanoPi R2S) and that the core userspace packages are from the official Debian APT repository, not an own repository, similar like Armbian, Raspberry Pi OS 64-bit, Rabian and what all those manufacturer "OS'es" are named. Other than DietPi, Armbian and manufacturer images at least ship with own kernels (that's the whole point of providing those at all, to make them booting on those particular SBCs), whether this makes them an own OS or not ;). We pick what we think is the best kernel, and apply the package composition, system tweaks and tools/scripts that make DietPi :).
