Can't seem to get remote desktop to work Topic is solved
moiner3000
Re: Can't seem to get remote desktop to work
Post by moiner3000 »
I used 192.168.178.49:1 which is the address of my Raspberry Pi
let's check status of VNC Server and what port it is running on
systemctl status vncserver.service
ss -tulpn | grep LISTEN
moiner3000
Yup, that was the problem!
When I typed in the first command I got this response:
Not really sure why that wasn't installed but anyways, I installed TigerVNC and now it's working fine.
Thank you so much for helping me out!
thats strange. How did you installed XRDP? did you used dietpi-software?
moiner3000
No, I installed it with
$ sudo apt-get install xrdp
Was that the problem?
that's the problem. If you would have used dietpi-software, all dependencies would be installed automatically. DietPi magic would take care on everything. :D
Just running apt-get install xrdp will not pull TigerVNC. Therefore it was needed to install TigerVNC manually. ;)
moiner3000
Ah alright!
Will install stuff via the dietpi-software in the future, again thank you so much for helping mate
