Raspberry PI 1 B Model Issues with Media Topic is solved
Re: Raspberry PI 1 B Model Issues with Media
Can you verify that the Raspbian Jellyfin repo has been installed as expected: cat /etc/apt/sources.list.d/dietpi-jellyfin.list
This should have been fixed with the first beta already: https://github.com/MichaIng/DietPi/comm ... 1204bf8623
If that does not support armv6l, then the repository is worthless as any other architecture can use the Debian Jellyfin repo.
@MichaIng
I did another test on my RPi1B running DietPi v6.34.3. Jellyfin is failing
root@DietPi1:~# systemctl status jellyfin.service
● jellyfin.service - Jellyfin Media Server
   Loaded: loaded (/lib/systemd/system/jellyfin.service; disabled; vendor preset: enabled)
  Drop-In: /etc/systemd/system/jellyfin.service.d
           └─jellyfin.service.conf
   Active: failed (Result: signal) since Mon 2020-12-21 13:17:10 CET; 28min ago
  Process: 397 ExecStart=/usr/bin/jellyfin ${JELLYFIN_WEB_OPT} ${JELLYFIN_RESTART_OPT} ${JELLYFIN_FFMPEG_OPT} ${JELLYFIN_SERVICE_OPT} ${JELLYFIN_NOWEBAPP_OPT} (code=killed, signal=SEGV)
 Main PID: 397 (code=killed, signal=SEGV)
Dec 21 13:17:10 DietPi1 systemd[1]: jellyfin.service: Service RestartSec=100ms expired, scheduling restart.
Dec 21 13:17:10 DietPi1 systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 5.
Dec 21 13:17:10 DietPi1 systemd[1]: Stopped Jellyfin Media Server.
Dec 21 13:17:10 DietPi1 systemd[1]: jellyfin.service: Start request repeated too quickly.
Dec 21 13:17:10 DietPi1 systemd[1]: jellyfin.service: Failed with result 'signal'.
Dec 21 13:17:10 DietPi1 systemd[1]: Failed to start Jellyfin Media Server.
root@DietPi1:~#
root@DietPi1:~# sudo -u jellyfin /usr/bin/jellyfin --webdir=/usr/share/jellyfin/web --restartpath=/usr/lib/jellyfin/restart.sh --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg
Segmentation fault
root@DietPi1:~#
And, as above check, the package is definitely installed from the Raspbian branch of the repository?
Get:3 https://repo.jellyfin.org/raspbian buster InRelease [6637 B]
Get:4 https://fra1.mirror.jellyfin.org/debian buster/main armhf Packages [1639 B]
Fetched 8276 B in 6s (1464 B/s)
Seems to be fechted from debian?? But source list looks fine
root@DietPi1:~# cat /etc/apt/sources.list.d/dietpi-jellyfin.list
deb https://repo.jellyfin.org/raspbian/ buster main
root@DietPi1:~#
Oh... their mirror director does not respect the Raspbian/Debian separation. It seems that https://repo.jellyfin.org/raspbian is redirected to https://fra1.mirror.jellyfin.org/debian while https://fra1.mirror.jellyfin.org/raspbian would be actually available :roll:.
I just reported it: https://github.com/jellyfin/jellyfin-meta/issues/5
Okay, sad fact: Jellyfin cannot run on ARMv6 boards, i.e. Raspberry Pi 1 and Zero models. This is an issue with .NET core itself: https://github.com/dotnet/runtime/issues/7764
The "raspbian" repo directory only exists so that $( awk -F'=' '/^ID=/{ print $NF }' /etc/os-release ) from the downloads page can be used on Raspbian as well, but it is a symlink or internal rewrite to the Debian binaries anyway, so does not mean its Raspbian armv6hf binaries.
- https://github.com/jellyfin/jellyfin/issues/5011
- https://github.com/jellyfin/jellyfin/issues/4959
So we need to disable the install option on those boards. But to be clear, a media server on RPi 1 or Zero would anyway not be of joy I guess, unless it's for SD videos or audio only ;).
