[Tutorial] installing Tonido (light personal cloud server)
Fourdee
Re: [Tutorial] installing Tonido (light personal cloud serve
Post by Fourdee »
johnvick wrote:Got this going on XU4 and after some problems with the apps not starting - fixed by putting armv7l in all the manifest.xml files (five of them) - working well. Ipad and Android apps sync nicely.
For ease of use and nice web interface this beats OwnCloud and NextCloud by miles.
Thanks to sinistergfx for the above tutorial.
John
Thanks guys,
Seems popular, i'll set this for v148 milestone, we'll get this into DietPi-Software (many thanks to sinistergfx's great tutorial) :)
https://github.com/Fourdee/DietPi/issues/592
Fourdee
Post by Fourdee »
johnvick wrote:I have it working on XU4 and Orange Pi Zero. So you should be OK. What is a useful feature, the WIndows sync app, is not supported on the ARM version of this software.
John
Wish I read this earlier lol:
https://github.com/Fourdee/DietPi/issue ... -289464754
johnvick
Legend
Post by johnvick »
Fourdee
Post by Fourdee »
johnvick wrote:Got that info from their forum:
http://www.tonido.com/forum/viewtopic.p ... ick#p41484
Thanks John :)
MichaelTew
Contact:
Tutorial installing Tonido light personal cloud server
Post by MichaelTew »
thanks very helpful tutorial to me. One question, do you only have the trails in one frame each?
metrolan
Re: [Tutorial] installing Tonido (light personal cloud server)
Post by metrolan »
sinistergfx wrote: Wed Nov 02, 2016 6:37 pm
4) Start Tonido server:
sudo ./tonido.sh start &
Mine gets freezed here:
root@DietPi:/usr/local/tonido# Starting Tonido Service:nohup: se redirige la salida de error a la salida estándar
The spanish paragraph only says: error output redirected to standar output
But I can still works with other ssh connection.
MonZon
Post by MonZon »
Any updates on WIndows Sync App + RPi3 issue?
johnvick
Legend
Post by johnvick »
My info may be out of date (check the Tonido forums maybe) but the Windows sync app didn't work with Tonido installed on ARM devices and the developers did not have any plans to make it work. I have Tonido on a Z83 device and the Windows sync works.
John
MonZon
Post by MonZon »
Thanks for the info.
I couldn't find anything not-so-old on their forums.
