Amiberry Autostart problem on tinkerboard
Re: Amiberry Autostart problem
Hehe, note the line break, at best execute the first line separately, then the second line ;).
bigly
Post by bigly »
Sorry
bigly
Post by bigly »
status
Re: Amiberry Autostart problem on tinkerboard
if possible, connect via SSH to your system and copy/past the result. That's easier than reading screen shots ;)
Okay, lets go through the following tests:
cd /tmp
wget https://mirrors.netix.net/armbian/apt/pool/buster-desktop/libm/libmali-rk/libmali-rk-midgard-t76x-r14p0-r0p0_1.6-1-0armbian1_armhf.deb
dpkg -i --force-all libmali-rk-midgard-t76x-r14p0-r0p0_1.6-1-0armbian1_armhf.deb
systemctl restart amiberry
# If it still fails try the Mesa drivers
apt install libgles2 libegl1 libgbm1
If (only) the last works, I will need to either build SDL2 against the matching development package of the Mali drivers we use, keep using the default Mesa drivers. AFAIK the Mesa drivers do not serve good performance with the version shipped in Debian Buster. Probably I take this as a chance to build the newest Mesa drivers with much better performance/support for Mali graphics, from what I read.
bigly
Post by bigly »
hi
the problem remains after executing first and second line :
cd /tmp
wget https://mirrors.netix.net/armbian/apt/p ... _armhf.deb
root@DietPi:~# systemctl status amiberry
● amiberry.service - Amiberry Amiga Emulator (DietPi)
Loaded: loaded (/etc/systemd/system/amiberry.service; disabled; vendor preset
: enabled)
Active: failed (Result: exit-code) since Sat 2020-11-07 17:51:41 G
MT; 3min 12s ago
Docs: https://github.com/midwan/amiberry/wiki
Process: 785 ExecStart=/mnt/dietpi_userdata/amiberry/amiberry (code=ex
ited, status=255/EXCEPTION)
Main PID: 785 (code=exited, status=255/EXCEPTION)
Nov 07 17:51:40 DietPi systemd[1]: Started Amiberry Amiga Emulator (DietPi).
Nov 07 17:51:41 DietPi amiberry[785]: Unable to create window: Could not initial
ize EGL
Nov 07 17:51:41 DietPi systemd[1]: amiberry.service: Mai
n process exited, code=exited, status=255/EXCEPTION
Nov 07 17:51:41 DietPi systemd[1]: amiberry.service: Fai
led with result 'exit-code'.
root@DietPi:/tmp# wget https://mirrors.netix.net/armbian/apt/p ... _armhf.deb
--2020-11-07 18:04:06-- https://mirrors.netix.net/armbian/apt/p ... _armhf.deb
Resolving mirrors.netix.net (mirrors.netix.net)... 87.121.121.2
Connecting to mirrors.netix.net (mirrors.netix.net)|87.121.121.2|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 7281572 (6.9M)
Saving to: ‘libmali-rk-midgard-t76x-r14p0-r0p0_1.6-1-0armbian1_armhf.deb’
libmali-rk-midgard-t76x-r14p0-r0p0_1.6-1-0armbian1_armhf.de 100%[========================================================================================================================================>] 6.94M 179KB/s in 30s
2020-11-07 18:04:42 (236 KB/s) - ‘libmali-rk-midgard-t76x-r14p0-r0p0_1.6-1-0armbian1_armhf.deb’ saved [7281572/7281572]
root@DietPi:/tmp# apt install libgles2 libegl1 libgbm1
Reading package lists... Done
Building dependency tree
libegl1 is already the newest version (1.1.0-1).
libgles2 is already the newest version (1.1.0-1).
libgbm1 is already the newest version (18.3.6-2+deb10u1).
In which order did you run the commands?
The idea was:
  1. Code: Select all
    cd /tmp
    Then check Armbian status.
  2. If the first failed:
    Then check Armbian status again.
And another thing, could you check:
ls -al /dev/mali*
modinfo mali
