RaspberryPi4 RPi4 Upgrading from existing SD card setup to boot from SSD
Re: RaspberryPi4 RPi4 Upgrading from existing SD card setup to boot from SSD
Usually this should be fine. Strange that it was not working on another SD card as well.
RollingDutch
Contact:
Post by RollingDutch »
Even found another problem.
Armv8 (64bit) doesn't work, but the 32bit version does. Problem is that a WordPress backup (Backupguard) needs 64 bits to restorre the bakups..
usually there shouldn't be any difference. How long did you wait on the 64bit version to boot?
