RaspberryPi4 RPi4 Upgrading from existing SD card setup to boot from SSD
billouetaudrey
Re: RaspberryPi4 RPi4 Upgrading from existing SD card setup to boot from SSD
Post by billouetaudrey »
It's working ;)
Thanks so much :D
thx for confirmation that the procedure is working for you as well. :D
billouetaudrey
For those want to know, I buy (120gb), I plugged to the USB2 because not recognize on the USB 3.0, Maybe it's my cable or something like that, I need to retry with new cable ;)
https://www.amazon.fr/PNY-CS900-Disque- ... 4119696677
and
https://www.amazon.fr/Bo%C3%AEtier-POSU ... 4119696677
Regarding USB boot on USB3, probably you are suffering from this issue as well https://github.com/MichaIng/DietPi/issues/3858
A solution is provided on the last post. Maybe you can give it a try.
billouetaudrey
Joulinar wrote: Wed Nov 25, 2020 3:47 pm Regarding USB boot on USB3, probably you are suffering from this issue as well https://github.com/MichaIng/DietPi/issues/3858
I just do this :
echo -e 'blacklist uas\nblacklist sg' > /etc/modprobe.d/disable_uas.conf
Nothing change for me, SSD ON USB 3 not booting
I have this
As I see you reported this in Github as well. Ok I guess @MichaIng will have a look.
billouetaudrey
Joulinar wrote: Wed Nov 25, 2020 6:54 pm As I see you reported this in Github as well. Ok I guess @MichaIng will have a look.
Yes because I think it's the better place, If I boot successfully, I will reported here ;)
beko
Post by beko »
Sorry, but it also does not work for me.
I followed the "instructions" and ended up with the dietpi/raspberry pi boot screen saying
SD card not detected
Failed to open device: 'sdcard'
And I was wondering how the Raspi should "know" that it now has to boot from the attached USB/SSD instead of the formerly used sd-card.
My setup:
Raspberry Pi 4
bootloader: a5e1b95f Apr 16 2020
boot: mode 6 order 0x00000001 rsts 0x00001000
billouetaudrey
beko wrote: Thu Dec 10, 2020 6:42 pm Sorry, but it also does not work for me.
My setup:
Raspberry Pi 4
Your BL is old
Try to do this :
sudo nano /etc/default/rpi-eeprom-update
change to beta like :
FIRMWARE_RELEASE_STATUS="beta"
Exit and save
sudo rpi-eeprom-update
root@raspberrypi:/home/dietpi/Jdownloader/cfg# sudo rpi-eeprom-update
BCM2711 detected
Dedicated VL805 EEPROM detected
BOOTLOADER: up-to-date
CURRENT: mardi 24 novembre 2020, 15:08:04 (UTC+0000) (1606230484)
LATEST: mardi 24 novembre 2020, 15:08:04 (UTC+0000) (1606230484)
FW DIR: /lib/firmware/raspberrypi/bootloader/beta
VL805: up-to-date
CURRENT: 000138a1
LATEST: 000138a1
You will have this after reboot ;)
beko
Post by beko »
Thank you so much... this time it worked!
Problem solved!
