dietpi_userdata -> /mnt/14BEBE5BBEBE3558/dietpi_userdata
pls restart your system and post output of systemctl status syncthing.service afterwards.
● syncthing.service - Syncthing (DietPi)
Loaded: loaded (/etc/systemd/system/syncthing.service; disabled; vendor prese
t: enabled)
Active: active (running) since Thu 2020-10-08 14:35:44 CEST; 1min
19s ago
Main PID: 649 (syncthing)
Tasks: 22 (limit: 1485)
CGroup: /system.slice/syncthing.service
├─649 /opt/syncthing/syncthing -no-browser -no-restart -logflags=0 -h
ome=/mnt/dietpi_userdata/syncthing
└─745 /opt/syncthing/syncthing -no-browser -no-restart -logflags=0 -h
Okt 08 14:35:51 MediaPi syncthing[649]: [7VQ4O] INFO: TCP listener ([::]:22000)
starting
Okt 08 14:35:51 MediaPi syncthing[649]: [7VQ4O] INFO: Relay listener (dynamic+ht
tps://relays.syncthing.net/endpoint) starting
Okt 08 14:35:51 MediaPi syncthing[649]: [7VQ4O] INFO: Completed initial scan of
sendreceive folder "Default Folder" (default)
Okt 08 14:35:52 MediaPi syncthing[649]: [7VQ4O] INFO: GUI and API listening on 1
27.0.0.1:8384
Okt 08 14:35:52 MediaPi syncthing[649]: [7VQ4O] INFO: Access the GUI via the fol
lowing URL: http://127.0.0.1:8384/
Okt 08 14:35:52 MediaPi syncthing[649]: [7VQ4O] INFO: My name is "MediaPi"
Okt 08 14:36:02 MediaPi syncthing[649]: [7VQ4O] INFO: Detected 4 NAT services
Okt 08 14:36:11 MediaPi syncthing[649]: [7VQ4O] INFO: quic://0.0.0.0:22000 detec
ted NAT type: Port restricted NAT
Okt 08 14:36:11 MediaPi syncthing[649]: [7VQ4O] INFO: quic://0.0.0.0:22000 resol
ved external address quic://93.135.20.201:63402 (via stun.syncthing.net:3478)
Okt 08 14:36:27 MediaPi syncthing[649]: [7VQ4O] INFO: Joined relay relay://195.2
19.166.59:443
Okt 08 14:35:52 MediaPi syncthing[649]: [7VQ4O] INFO: GUI and API listening on 127.0.0.1:8384
cat config.xml|grep address
cat /mnt/dietpi_userdata/syncthing/config.xml|grep address
<address>dynamic</address>
<address>127.0.0.1:8384</address>
sed -i 's/127.0.0.1:8384/0.0.0.0:8384/g' /mnt/dietpi_userdata/syncthing/config.xml
systemctl restart syncthing.service
lsof -i -P -n | grep LISTEN
dropbear 586 root 3u IPv4 16513 0t0 TCP *:22 (LISTEN)
dropbear 586 root 4u IPv6 16514 0t0 TCP *:22 (LISTEN)
smbd 652 root 29u IPv6 16742 0t0 TCP *:445 (LISTEN)
smbd 652 root 30u IPv6 16743 0t0 TCP *:139 (LISTEN)
smbd 652 root 31u IPv4 16744 0t0 TCP *:445 (LISTEN)
smbd 652 root 32u IPv4 16745 0t0 TCP *:139 (LISTEN)
java 660 ubooquity 44u IPv6 16212 0t0 TCP *:2039 (LISTEN)
java 660 ubooquity 52u IPv6 17130 0t0 TCP *:2038 (LISTEN)
jellyfin 667 jellyfin 280u IPv6 16382 0t0 TCP *:8096 (LISTEN)
kodi.bin_ 752 root 28u IPv4 18841 0t0 TCP 127.0.0.1:50067 (LISTEN)
kodi.bin_ 752 root 30u IPv4 18802 0t0 TCP 127.0.0.1:52530 (LISTEN)
kodi.bin_ 752 root 34u IPv4 18850 0t0 TCP 127.0.0.1:60113 (LISTEN)
kodi.bin_ 752 root 38u IPv6 16197 0t0 TCP *:8080 (LISTEN)
kodi.bin_ 752 root 39u IPv4 16198 0t0 TCP *:8080 (LISTEN)
kodi.bin_ 752 root 40u IPv6 16204 0t0 TCP [::1]:9090 (LISTEN)
kodi.bin_ 752 root 42u IPv4 16205 0t0 TCP 127.0.0.1:9090 (LISTEN)
kodi.bin_ 752 root 43u IPv4 18852 0t0 TCP 127.0.0.1:44901 (LISTEN)
