Spotcast Topic is solved
novitibo
Re: Spotcast
Post by novitibo »
Joulinar wrote: Sat Sep 26, 2020 7:14 pm so basically you installed the spotify-token package via pip3 install as I described above. Plus Debian packages libxml2-dev libxslt-dev python-dev? Hmm strange because HA should have it's own python environment. :?
yeah, I was thinking the same and first tried to install via debian apt install and it worked
Re: Spotcast
just out of interesst, where did you know to install libxml2-dev libxslt-dev ??
novitibo
Re: Spotcast
Post by novitibo »
If I remember correctly I got the info from pip during pip spotify-token install - sorry, no ssh log file :roll:
Re: Spotcast
ok so basically installation of spotify-token did the trick
novitibo
Re: Spotcast
Post by novitibo »
Correct 8)
