samba network
negubill
Re: samba network
Post by negubill »
good afternoon helps me create or create additional SAMBA shares for my HDDs.
negubill
Re: samba network
Post by negubill »
help
Re: samba network
Hi, for this open /etc/samba/smb.conf and add + adjust an additional block to the end of the file, that looks like this:
[myshare]
	comment = my share
	path = /mnt/myHDD
	browseable = yes
	create mask = 0664
	directory mask = 0775
	valid users = dietpi
	writeable = yes
	max connections = 1
The name in the square brackets is what needs to be used when adding the share to a remove Samba client, the comment is more like a visual name. Depending on your requirements, authentication user and permission modes can be adjusted of course, the above example matches the default dietpi share accessible by the dietpi user and files+dirs are created a way that all members of the dietpi group have write access as well, e.g. download and media software.
negubill
Re: samba network
Post by negubill »
root @ DietPi: ~ # /etc/samba/smb.conf
bash: /etc/samba/smb.conf: Permission denied
root @ DietPi: ~ #
trendy
Re: samba network
Post by trendy »
sudo vim /etc/samba/smb.conf
Re: samba network
it should be fine to do
nano /etc/samba/smb.conf
@trendy
usually vim is not installed by default if I'm not mistaken
trendy
Re: samba network
Post by trendy »
Maybe you are right @Joulinar, I don't remember if it exists as symbolic link to vi. I immediately install it anyway on first boot.
Re: samba network
The editor command should btw always work and is bound by the alternatives system to any newly installed editor:
2020-11-01 18:56:38 root@micha:/mnt/sda# which editor
/usr/bin/editor
2020-11-01 18:56:41 root@micha:/mnt/sda# l /usr/bin/editor
lrwxrwxrwx 1 root root 24 Aug 20 12:29 /usr/bin/editor -> /etc/alternatives/editor
2020-11-01 18:56:45 root@micha:/mnt/sda# l /etc/alternatives/editor
lrwxrwxrwx 1 root root 9 Aug 20 12:29 /etc/alternatives/editor -> /bin/nano
negubill
Re: samba network
Post by negubill »
good guys, until today I couldn't put the discs on the network, I don't know much about linux, please could a friend help me,
Re: samba network
Were you able to edit /etc/samba/smb.conf as mentioned above? viewtopic.php?p=28237#p28237
