Please update Baikal
Re: Please update Baikal
ok good that you found a way around the Baikal bug. But hopefully thy will fix the direct upgrade as well :)
The newest Baikal version has the pre-v0.7.0 migration now fixed: https://github.com/sabre-io/Baikal/pull/979
So upgrading via dietpi-software reinstall 57 or manually via https://sabre.io/baikal/upgrade/ should now work fine on all versions.
nope, still not working as they did not create a new version. It's still 0.7.1. I guess we would need to wait for a new release to be published.
Yes sorry, I was a bid hasty, the fix has been merged into upstream code but not yet been released. So currently one would need to install the master branch code manually (following the upgrade guide I linked): https://github.com/sabre-io/Baikal/arch ... ter.tar.gz
But I think its reasonable to wait for a final release, so all code has been reviewed and tested as of their release schedule: https://github.com/sabre-io/Baikal/releases
omavoss
[solved] Re: Please update Baikal
Post by omavoss »
for the archive:
I have upgraded from Baikal 0.7.1 to 0.7.2 without any problems.
Many greetings.
Great, yes after 0.7.0 there should be no issues anymore :).
0.7.2 contains the fix to be able to update from 0.6 now
