Raspberry Pi 4 Boot from SSD Topic is solved
baz123
Re: Raspberry Pi 4 Boot from SSD
Post by baz123 »
Flashing the SSD with DietPi and booting to SSD worked for me - RPi4
I did have Raspbian installed before, so updated the bootloader first and set the options correctly before flashing the SSD.
yes indeed you can move RootFS to SSD only and keep BootFS on MicroSD
manilx
Post by manilx »
trigrhappy wrote: Fri Oct 02, 2020 8:02 pm
Joulinar wrote: Sat Sep 26, 2020 7:18 pm pls let us know if it was working to flash the image directly to SSD and boot from it. As this is quite a new functionality on Raspberry OS, it would be good to have some success stories ;)
FYI, I've been running dietpi directly from my SSD plugged into my USB3 port on my Raspberry Pi 4 4GB for about 2 months now. It's worked like a charm.
Just had to make sure I was running the latest bootloader software, then I used my normal image writer to write the dietpi image to the ssd (just as I did many times with sdcards), plugged the ssd into my USB3 port..... pulled out the sdcard, and pressed power.
It has worked flawlessly.
Same here for a few months....
thx for sharing. :)
