NTFS write speed
FalconX
Re: NTFS write speed
Post by FalconX »
The logfile paragon-ufsd-install.log doesn't exist.
Thanks for having a look.
I try my luck in the Paragon support forum.
ok, pls keep us posted how it goes
FalconX
Post by FalconX »
I got no answer in the Paragon forum, but I've updated the NTFS-3G driver.
The one which comes with DietPi is outdated, I think it was from 2015, the newest is from 2017.
I would say the write speed is faster now, read speed was good before anyway.
Nevertheless I get the the same results concerning the low speed, when running the DietPi Benchmark tool... but don't know, I would say its better now.
Might switch to ext4 in the future, we'll see.
probably you can share what you have done to update the driver. Maybe there are other, who like to know what you have done ;)
FalconX
Post by FalconX »
Joulinar wrote: Thu Oct 01, 2020 10:26 pm probably you can share what you have done to update the driver. Maybe there are other, who like to know what you have done ;)
Sure, I followed this tutorial:
https://www.htpcguides.com/install-late ... an-ubuntu/
ok so basically you compiled your own one. What version do you have now? On my RPi3B+, I get the following if I install ntfs-3g from apt repository.
root@DietPi3:~# ntfs-3g --version
ntfs-3g 2017.3.23AR.3 integrated FUSE 28
root@DietPi3:~#
