No response traffic on application after port forward Topic is solved
S10
Re: No response traffic on application after port forward
Post by S10 »
I did a reboot without removing lsof and i'm back at square 1 :-(
root@DietPi:~# tcpdump -n -i eth0 port 443
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
17:52:12.001598 IP 109.36.143.39.1344 > 192.168.1.20.443: Flags [S], seq 1941187099, win 65535, options [mss 1300,nop,wscale 7,nop,nop,TS val 458575080 ecr 0,sackOK,eol], length 0
17:52:12.360788 IP 109.36.143.39.1344 > 192.168.1.20.443: Flags [S], seq 1941187099, win 65535, options [mss 1300,nop,wscale 7,nop,nop,TS val 458575447 ecr 0,sackOK,eol], length 0
17:52:12.508828 IP 109.36.143.39.1344 > 192.168.1.20.443: Flags [S], seq 1941187099, win 65535, options [mss 1300,nop,wscale 7,nop,nop,TS val 458575583 ecr 0,sackOK,eol], length 0
17:52:12.648418 IP 109.36.143.39.1344 > 192.168.1.20.443: Flags [S], seq 1941187099, win 65535, options [mss 1300,nop,wscale 7,nop,nop,TS val 458575719 ecr 0,sackOK,eol], length 0
17:52:13.480744 IP 109.36.143.39.1344 > 192.168.1.20.443: Flags [S], seq 1941187099, win 65535, options [mss 1300,nop,wscale 7,nop,nop,TS val 458576557 ecr 0,sackOK,eol], length 0
17:52:24.672036 IP 109.36.143.39.1344 > 192.168.1.20.443: Flags [S], seq 1941187099, win 65535, options [mss 1300,sackOK,eol], length 0
Something changed in between the reboot. i didnt change anything but installed lsof. Maybe the iptables?
root@DietPi:~# iptables --list
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
S10
Post by S10 »
Solved it!
I totally forgot that on the background i was running a vpn connection which conflicts with my portforward rules. Becasuse the traffic is rerouted through the vpn tunnel and so the reply traffic is tunneled through a totally different public ip than it came in.
Disabling the vpn, and the port forward works.
uh yeah that's a good reason. Good that you found it. 8)
