Implement DynDNS - dynu.com
naddel81
Re: Implement DynDNS - dynu.com
Post by naddel81 »
the problem is not updating it, the main problem is that it needs a manual interaction every x days (30 days, I guess) to function.
that is really unnecessary and was not the case in No-IP's earlier days.
this was not a feedback on your post @naddel81 as you can see on the quote
ravenclaw900 wrote: Mon Apr 19, 2021 8:54 pm
MichaIng wrote: Tue Jan 26, 2021 3:30 pm Looking at the No-IP client, it has not been updated for years, it's CLI is not very intuitive etc, it's simply unnecessary :D.
It looks like No-IP can also be updated from URL, see https://www.noip.com/integrate/request.
I found that just yesterday as well. Already implemented. If the noip2 client is found on the system, it suggests to remove it in favour of the new Cron+cURL-based setup. The dedicated No-IP software install option is removed. I'll open a PR tomorrow.
